Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 28, 2013 at 11:37 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    wanna bet? not factory i mean. the aftermarket ones.
  2. Sep 28, 2013 at 11:37 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    19mm is stock
  3. Sep 28, 2013 at 11:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I am pretty sure my Toytechs were 17-19..
  4. Sep 28, 2013 at 11:39 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Mine are also 27mm
  5. Sep 28, 2013 at 11:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    4301T-AP-GR--15
    Is this the nut size or the bolt diameter?
  6. Sep 28, 2013 at 11:46 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you got pussy bolts on them there son...
    mine, thats a 19 next to it
  7. Sep 28, 2013 at 11:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Huh..maybe there were 27..idk. Been over a year since i have touched em..haha
  8. Sep 29, 2013 at 12:03 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    nut size. bolt diameter is 18mm
  9. Sep 29, 2013 at 1:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Sep 29, 2013 at 10:10 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  11. Sep 29, 2013 at 10:11 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    jeez Monte, you should have got the 70d it has in camera hdr :p
  12. Sep 29, 2013 at 11:58 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Photomatrix pro.
    Shutup i know!! haha
  13. Sep 29, 2013 at 1:36 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Mike, i know you already ordered them but the AP poly bushings measure 1.5" OD and 3/4" ID.
  14. Sep 29, 2013 at 2:01 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I think when I do 35s....ill take my factory front fenders off, and since i have a spare set of front fenders, ill just paint em black ( they are green, but the 01 green) and cut a full 2" out of them and just run them for who knows how long. Then if anything happens, i still have my nice pretty factory fenders
  15. Sep 29, 2013 at 2:05 PM
    SconnieHailer
    Marc
    haha, i'm still 100% happy with my 60d. Takes awesome pictures just fine :cool: If I was a gear slut i'd totally be freakn out tho haha. (not calling you a gear slut)
  16. Sep 29, 2013 at 2:11 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Good plan. Stoked on tubing yet? haha
  17. Sep 29, 2013 at 2:21 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i want some dam 35s haha!
    but i have an unknown amount of time to wait :(
    when I first got the hankering for 35s i was really hesitant on tubbing, but now im all fuck yes lets do this! I might even be able to steal one of my dad's work's decent mig welders, and quit fucking around with the flux core one. I just hope I dont burn down my truck like joe did. that would piss me off haha.
  18. Sep 29, 2013 at 2:36 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Pm sent
  19. Sep 29, 2013 at 2:48 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You should turbo your 3rz first. Then you can tell Ben and Monte to SUCK ON DEEZ NUTZZZ
  20. Sep 29, 2013 at 2:49 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
