Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 30, 2013 at 9:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well considering Mike is probably gonna be boosted WELL before you..id say Mike does..haha
  2. Sep 30, 2013 at 9:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet! Same as me :D haha
    you should get longer shocks now :boink: :p haha
  3. Sep 30, 2013 at 9:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :rofl:
  4. Sep 30, 2013 at 9:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I will be curious to see how my current foxes do before I decide. I have to convince Mark to let me do the forklift flex out to see what the numbers produce. :D
    In case you have forgotten I have a set of 9.5" travel 5125s just sitting here if I need them.
  5. Sep 30, 2013 at 9:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Those are not the numbers he is referring to. :p
  6. Sep 30, 2013 at 9:34 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    :woot: same one's i have too.
    i just retrofitted mine with greaseable bolts :cool:
  7. Sep 30, 2013 at 9:35 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Me too. What should i get?
  8. Sep 30, 2013 at 9:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Well, I don't think you have anything to worry about. You are still TWs version of John Holmes I'm sure. :eek:
    I can think of a couple of ways to test this.
  9. Sep 30, 2013 at 9:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh? Tell me more please
  10. Sep 30, 2013 at 9:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you put billies on your truck..pffff..only temporary haha
    and if yours droops anything like mine..which..since its a long pack..:notsure: id say they will be too short. But too long so new bumps needed too.
    go meassure your flex man. Most trucks are different. Id guess a 10'' stroke though and big bump stops..or shock relocate. but no idea unless you meassure.
  11. Sep 30, 2013 at 9:43 PM
    BradyT88
    BradyT88 Well-Known Member
    Superwerty wasn't running NOS. He was meth injected though with a smaller pulley (2.85" I think) and running E-85. I don't think he even achieved 400 RWHP, but he was running factory internals still. It may be possible now with the 2.55" pulley, but you had better have forged internals and be setup for it.
    2nd gens with the URD S/C can break 400HP but they don't make the low end torque that the TRD S/C does and even then 450 RWHP is about peak for them. Superwerty may have broke that with his larger S/C on his URD kit but he sold it before he ever built up his 4.0...:pout:
  12. Sep 30, 2013 at 9:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Look and see if I am noticeable. Probably just laughable. :p
  13. Sep 30, 2013 at 9:47 PM
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    picked up some greaseable bolts from low range, drilled out the smaller hole to 18mm, took out the metal sleeve and inserted new bolts. and voila!
  14. Sep 30, 2013 at 9:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What?? They are new. :confused: They ought to last at least a couple thousand miles before they start leaking. Hopefully by then we can do a shock relocate. Then I will spend some money on nice shocks if I need to.
  15. Sep 30, 2013 at 9:52 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    monte has this thing about billy's exploding
    MINE ARE FINE MONTE
    FINE
    F
    I
    N
    E
    STILL WORKING
    SO
    HA
    HAH
    A
    HA
  16. Sep 30, 2013 at 9:54 PM
    lunchboxhero
    lunchboxhero Out for a rip eh!
    Aleks
    Boise, Idaho
    marks on the other hand...... Heh..... not doing so hawt.
  17. Sep 30, 2013 at 9:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..well they will last then for that.
    yea..you..you mall krawl..you input on this..means..zero..
  18. Sep 30, 2013 at 9:57 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    All 4 of mine are fine
  19. Sep 30, 2013 at 9:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, makes sense. Low range sells just the bolts? Hmmm :cool:
    I've worked with machining polyurethane is a previous lifetime. Kind of tricky depending on the durometer. Did you use a lathe to enlarge the hole?
  20. Sep 30, 2013 at 9:58 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    picky's no worky
