Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 30, 2013 at 9:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    my fronts are find.
    my 10 5150s not so much. Its why they discontinued them tho. Bad seals. that and i was probably over compressing them.
  2. Sep 30, 2013 at 10:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You're not wheeling hard enough. :D
    Only a matter of time. :p
    this ^^
  3. Sep 30, 2013 at 10:03 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    im praying mine hold up. I can't afford to spend more money on shocks after dealing with these fucking fox's
  4. Sep 30, 2013 at 10:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    bumps were too short. :rolleyes:
  5. Sep 30, 2013 at 10:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    See..even in that shot..your not stuffing shit..or drooping even..looks like you sway bar was still on.
    I stand by my mall kraller statement :D haha
  6. Sep 30, 2013 at 10:05 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    i didn't touch the poly. i just drilled the side plates for the shackle. the metal sleeve is inside for the smaller bolt to basically just take up space. if you put the 18mm bolt in without the sleeve it should fit perfectly. the frame to shackle bolts just swapped one for the other
    keep in mind i'm not familiar with your leaf pack but it should fit the 18mm bolts in the poly
  7. Sep 30, 2013 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    but i like stuffing the tire all the way!!
  8. Sep 30, 2013 at 10:07 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Be pretty sweet but if your coming 200 miles then should go the extra 200 and hit up Moab lol the trails here are fun but not worth a 200 mile trip. But then again you could come down for snowboarding or something and then some snow wheeling lol
  9. Sep 30, 2013 at 10:07 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    it was. and the bed was unloaded.
    THATS NOT THE FUCKING POINT ASSHOLE
    :rofl:
  10. Sep 30, 2013 at 10:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just sayin...<3
    you porbably shoulda just done a fabtch lift and 3'' BL and then 18'' rims with like..20'' wide tires..be a HW bro in no time.
  11. Sep 30, 2013 at 10:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ANYTHING..flexes better then that.
    My lawn mower flexes better then my double cab
  12. Sep 30, 2013 at 10:12 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  13. Sep 30, 2013 at 10:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, very interesting. What springs do you have? Dakars?
    Yeah, and your billies leak as a result.
  14. Sep 30, 2013 at 10:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    worth it :cool:
    yea he has Dakars.
  15. Sep 30, 2013 at 10:13 PM
    BradyT88
    BradyT88 Well-Known Member
    1 of my rears is leaking but they are about 2" too short for this...
    Oh yeah? haha
  16. Sep 30, 2013 at 10:14 PM
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    you are correct sir. dakars and OME poly bushings
  17. Sep 30, 2013 at 10:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Im pretty sure that wheelers told me the OME bushings are OEM size, so same as mine.
  18. Sep 30, 2013 at 10:22 PM
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    easy peezy lemon squeezy. all you would need are bolts, nuts, and a drill bit. i used a unibit to make it a bit easier.
  19. Sep 30, 2013 at 10:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I found this interesting. The rigs, all going over the same obsticle on the Shoshone Lake trail. It is interesting to see how they flex. Granted you are wider that me by a little bit and the FRV is a bit longer than both of us. Still interesting.
  20. Sep 30, 2013 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea this is the place i would have like to see you on. I stil have about 1-2'' of droop i think.
    or if we had had time all do poser shots on the spot on Shoshone i did that big flex shot on last year.
    good find though. is kinda cool. My dads looks like it has no flex haha sway bar on..but all 3 trucks look about the same in terms of levelness..
