Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 30, 2013 at 10:34 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Eh, I can do that 20 minutes down the road from me :p
  2. Sep 30, 2013 at 10:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    .............:D
    lol I just noticed I have my old rear 5100's in the bed
  3. Sep 30, 2013 at 10:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    if i was home..could do it in less then 5 mins probably. i miss Wy..
    also..your not droopinga 33 below the sliders..make it happen..:p
  4. Sep 30, 2013 at 10:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  5. Sep 30, 2013 at 10:39 PM
    PcBuilder14
    Brent
    Nor Cal
    Better!? Haha
    That's pretty much all I've got... I need expos and to find a way to trim the flares on the inside about an inch...
  6. Sep 30, 2013 at 10:41 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I gotta load up the expos and go take some pics. The ones I have now don't do them justice
  7. Sep 30, 2013 at 10:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    shackles give you more droop. New leafs will help a bit but shackles will help a lot more.
    granted doesn't mean anything if you shocks are too short.
  8. Sep 30, 2013 at 10:43 PM
    BradyT88
    BradyT88 Well-Known Member
    Or two :D haha
  9. Sep 30, 2013 at 10:44 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    or if your leaf pack doesn't have the arch to support the added shackle movement
    otherwise it's just adding height
  10. Sep 30, 2013 at 10:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lockers are for wanna be wheelers..take a real driver to do it all open
    Jk..i really want lockers..
  11. Sep 30, 2013 at 10:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Both. :rolleyes:
    Max flex and lockers is the best tho. :stirthepot:
  12. Sep 30, 2013 at 10:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    im getting this done first..then lockers here we come.
  13. Sep 30, 2013 at 10:48 PM
    PcBuilder14
    Brent
    Nor Cal
    Well I want some leafs that can support an RTT but don't want to be lifted 5" in the rear! It's hard to find a good in-between so I can get some shackles.
    That's my problem. I was parked next to a stock Tacoma today and I honestly think I'm only 1" above stock in suspension :((not including tire height)
  14. Sep 30, 2013 at 10:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh like thats an excuse..hello..look at my rig..
    i have winch. Check.
  15. Sep 30, 2013 at 10:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. Didn't have to. But why would I make him move and pull out mine when his was ready to go.
    Sure thing. Actually. It's my next mod. 2k tho :eek:
  16. Sep 30, 2013 at 10:54 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    as far as travel goes, take a string and tie it to the ends of your leaf pack, following the leaf arch. pull the string taught, and wherever the end of the string is, is the overall shackle movement
    I feel you on the height though. with the shackles, my rear h/f is almost 28". :rofl:
  17. Sep 30, 2013 at 10:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    But we all know it was just karma. Since mike had to use my CO2. I used his winch. Full circle haha
  18. Sep 30, 2013 at 10:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    like this? :p
  19. Sep 30, 2013 at 11:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That day could come soon for you ;) especially after lockers.
    But I have no doubts ill enjoy it. Ill be able to push my truck harder then ever. Be awesome.
  20. Sep 30, 2013 at 11:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Say what?
