Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 5, 2013 at 6:54 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Ugh, I keep forgetting! Haha I thought 4:56 was good for 33's... :eek: Nevermind!
  2. Oct 5, 2013 at 6:55 PM
    BradyT88
    BradyT88 Well-Known Member
    Think you could give him a better run for his money this time around?
  3. Oct 5, 2013 at 6:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    for manuals 4.56s and 33s is ideal.
  4. Oct 5, 2013 at 6:56 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    that all depends on your factory gearing if you are 4.10 factory that's correct. im auto and im 4.88 is perfect for my 35's..
  5. Oct 5, 2013 at 6:57 PM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, yeah I'm 4:10 stock. So you're running 4:88's with 35's? How is it on the road?
  6. Oct 5, 2013 at 6:58 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    :rolleyes:
    I see what you did there... sweeeeet.
  7. Oct 5, 2013 at 6:58 PM
    BradyT88
    :woot:
  8. Oct 5, 2013 at 7:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    4.88s for 33's on an auto are perfect :cool:
    this ^^^
  9. Oct 5, 2013 at 7:11 PM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, conflicting....
  10. Oct 5, 2013 at 7:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I guess that means if you go with 4.88s now you'll be set for when you go to 35s...
    I would point out that neither you nor I have a supcrcharger either...
    yet! :)
  11. Oct 5, 2013 at 7:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Brady, bring out the numbers..
    4.88s are best for 33s and an auto.
    Great for 35s and a manual
    5.29s match autos better for 35s and 37s on manuals.
    Has to do with the gears ratios of the trannys. The AT overdrive is super tall. You'll still hunt for gears on the high way with 4.88s and 35s.
    Scotty at addicted offroad says the same basically
  12. Oct 5, 2013 at 7:26 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha this is true.
    Hmm, okay. It just sounds like 5:29's would be really low gearing for going 70mph on the highway.
  13. Oct 5, 2013 at 7:28 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    No way. The RG TT has 900 HP. Ever seen a truck pull wheelies at speed, on the dirt? This is an old truck too...
    http://www.youtube.com/watch?v=QJKLfRvLlms
  14. Oct 5, 2013 at 7:28 PM
    rctoy
    konstantenos
    Pocatello Idaho
    also depends on what generation taco you are.. brady and i are both auto. he needs 4.88 for 33's and i need 4.88 for 35's but mark was 4.56 factory gears so he need 5.29 for 35's is simple what was your factory gearing like i said in my first statement..
  15. Oct 5, 2013 at 7:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Would be with 33s probably. No so bad with 35s.
    Also there is a big misconception that lower rpms mean less mpgs. It doesn't since the load is decreased on the motor.
  16. Oct 5, 2013 at 7:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Only reason mark need 5.29s is because his drive train is 4cyl and auto transmission.
    Hs nothing to do with your stock gearing. All about the drive train.
  17. Oct 5, 2013 at 7:30 PM
    BradyT88
    Konsta has an S/C so that helps a lot on road and as you know the auto tranny is already pretty awesome offroad so the difference between 4.88's and 5.29's for 35's would be almost negligible really. Of course the 5.29's are going to be more nicer offroad they aren't necessary. If you want proof of that just go crawling in 4Hi. It's still really easy to do, you just have to push the throttle a little more. haha
    I run 4.88's with my 33's and pretty much everyone will tell you that is overkill but I love it and think it feel great. Wish I could go to 5.29's really, although that might suck at 75 mph on 33's for a 2nd gen.
  18. Oct 5, 2013 at 7:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Oct 5, 2013 at 7:35 PM
    BradyT88
    2nd gens don't need 4.88's 33's. It's overkill really. For me it is just planning ahead for 37's.
    How does it make since for me to run 3.73's for 31's and you to run 4.10's for 31's, and then we both run the same gears but you have a bigger tire than me?... It doesn't. I should have a bigger tire still. The catch is your S/C helps you out on road and the auto helps you out off road.
  20. Oct 5, 2013 at 7:39 PM
    BradyT88
    1st, That is fucking wicked! haha
    2nd, I just meant suspension wise. haha Granted he is probably linked and running I-beams up front or some shit. haha Not sure just how fast he can tear out across the trails but you can hit 110. From what I have seen a lot of the Trophy trucks run about 100 mph typically because of corners, sure he'll take you on a straight away, but if there are lots of turns and such to slow those ponies down then you think you could hold with him better?
