Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 6, 2013 at 8:33 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Technically infinity stroke, but if you had to quantify it maybe a 3 stroke is more accurate. Technologically, they are dinosaurs compared to F1 race engines and even modern sport bike engines like the MV Agusta F4RR. One liter displacement, 200 horsepower. That would be like getting 800HP out of our V-6 motors.
  2. Oct 6, 2013 at 8:36 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    ^ I need to read up on my new motor tech!!! 50 mm stroke :cool:
  3. Oct 6, 2013 at 8:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'd still consider rotaries 4 stokes. They still have an intake, compression, ignition, and exhaust "stroke"
  4. Oct 6, 2013 at 8:48 PM
    BradyT88
    BradyT88 Well-Known Member
    Torspd is trying to get 800 HP out of his 1GR:cool: It has a stroker kit on it making it a 4.4L (it's really about 0.5L bigger than stock now) and a big ass Turbo, can't remember the exact model. The motor is currently being built up pretty solid and he dropped the compression down to 9:1 or just under to allow for better performance under boost.
    Before all this he got almost 600HP out of it on a smaller turbo and almost 16 psi.
    He also has swapped out the OEM Tcase for an AWD tcase (33/66 front to rear power ratio) and the 6 spd OEM tranny for a T56.
  5. Oct 6, 2013 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Isn't he going twin turbo.
    And he also bored it.
  6. Oct 6, 2013 at 9:00 PM
    BradyT88
    No, I'm pretty sure he is sticking to just one turbo. Toon is the one that wants to go twins.
    He did bore it to like 15 thousandths, but that doesn't really affect displacement. Just cleans up the cylinder walls.
  7. Oct 6, 2013 at 9:09 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    True, but the F1 engines get 800HP out of 2.4liter displacement, all naturally aspirated (the 2014 motors will have turbos and be smaller). They can turn 20,000 rpms, but are limited to 18,000. Imagine if you boosted one.
    http://www.youtube.com/watch?v=o_QyUD6V5_I
  8. Oct 6, 2013 at 9:12 PM
    BradyT88
    Fuck that is crazy! I take it they aren't like a conventional engine are they? ie the same piston, crankshaft, etc setup like we have. Or do they just manage to hit those kinds of rpm by having less pistons and just being built for it?
  9. Oct 6, 2013 at 9:14 PM
    SconnieHailer
    Marc
    isn't f1 going v6 next year?
  10. Oct 6, 2013 at 9:14 PM
    SconnieHailer
    Marc
    Tolerance and design brah :cool:
  11. Oct 6, 2013 at 9:17 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    1.56" stroke. 3.85" bore (same size as a chevy 350). It's called an "oversquare" motor.
    yes, 1.6L compound turbo V6, but they will be limited to 15,000 rpm.
  12. Oct 6, 2013 at 9:24 PM
    SconnieHailer
    Marc
    Gonna be an interesting year for F1 next year! new sounds and all, hope it's not too much like the US Indy car series...
  13. Oct 6, 2013 at 9:28 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I think it will slow down lap times a lot for the first couple of years. It's getting pretty boring and predictable these days.
  14. Oct 6, 2013 at 9:38 PM
    BradyT88
  15. Oct 6, 2013 at 9:41 PM
    SconnieHailer
    Marc
    True. I like allowing teams to build the best car they can. If they dominate sweet! If not, then get on a new design and get competitive! Best way to improve a sport right there.
  16. Oct 6, 2013 at 9:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I would go to Patagonia.
  17. Oct 6, 2013 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    this^^
    F1 motors tolerances are sooo small that technically when the motor is cold..its a solid piece of metal. they have to heat up the motor before they can even start it.
    if only..
    that'll never happen.
    people like control too much, put rules on everything.
  18. Oct 6, 2013 at 10:04 PM
    SconnieHailer
    Marc
    Very true Ben, where have the days of old gone, when crazy was ridiculed until proven victorious!? Part of our stagnant engineering and keeping drivers at the forefront has stinted the ability to progress the sport/engineering genius beyond what it is capable of with the current limitations... Lets bring back a bit of crazy and make it a bit more about the mesh of driver and machine!
  19. Oct 6, 2013 at 10:46 PM
    BradyT88
    :eek:
  20. Oct 6, 2013 at 10:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha nice Ben haha
    i did...nothing this weekend haha homework..and it rain a lot. so no biking and photos. think fall is starting to come here.
