Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 30, 2013 at 8:01 AM
    scocar
    scocar hypotenoper
    Ah, yeah. I was looking at putting an LCE header on mine, and it was gutless in the mountain highways with a load. But it would crawl up a wall. But then half of that is tranny.
  2. Oct 30, 2013 at 8:49 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I did that to mine did a cam and injectors and header intake mods all sorts of shit.. it would smoke the tires in first gear but on the freeway still was a pile.. got good mpgs and would walk up a wall in 4lo but no high speed stuff.. good motor if you dont mind the lack of power.
    Point i was making is if you want that power swap in a bigger motor.. there is no replacement for displacement..
  3. Oct 30, 2013 at 8:53 AM
    scocar
    scocar hypotenoper
    Yes. Dependable, yes (as long as the timing chain guides don't go south unnoticed), fast, no. Especially in a 4x4 Xtra cab...
  4. Oct 30, 2013 at 9:48 AM
    rctoy
    konstantenos
    Pocatello Idaho
    get a 20R timming chain kit for it double roller and steel guids.. problem solved:cool:
    EDIT: i you have to get the 20R oil pump drive or cut the 22R oil pump drive down..
  5. Oct 30, 2013 at 10:12 AM
    scocar
    scocar hypotenoper
    I don'thave one anymore, but yeah, I remember inspecting the plastic guides every time I did the valves, and I researched the metal replacement guides just in case...
    Yay interference engines...:rolleyes:
  6. Oct 30, 2013 at 10:45 AM
    rctoy
    konstantenos
    Pocatello Idaho
    no different then the 3.4 only it has a beefy belt.. seen a factory belt go 180K and not break the water pump on the other hand didnt fair so well.
  7. Oct 30, 2013 at 11:02 AM
    scocar
    scocar hypotenoper
    I understood that the 3.4s are non-interference.
  8. Oct 30, 2013 at 11:47 AM
    rctoy
    konstantenos
    Pocatello Idaho
    I think youre thinking of the 3.0V6 it was a non-interference engine.
  9. Oct 30, 2013 at 11:56 AM
    BradyT88
    BradyT88 Well-Known Member
    Or the 4.0. I believe it is non interference.
  10. Oct 30, 2013 at 12:52 PM
    scocar
    scocar hypotenoper
    http://www.yotatech.com/f2/how-many-miles-your-3-4l-timing-belt-55233/index4.html#post572136
    :notsure:
    BruceTS
    Contributing Member
    Personal Sales Rating: (0)
    Ok, let's settle this once and for all.... for the 1999 Toyota 3.4L engine, they are non-interference. this is from actual measurments of the valves at full open, Both the [COLOR=blue !important][COLOR=blue !important]intake
    [/COLOR] and exhaust extend 3.8mm beyond the mating surface of the head. The piston is cupped and is 4.6mm deep. that is a .8mm gap without adding the thickness of the head [COLOR=blue !important][COLOR=blue !important]gasket[/COLOR][/COLOR].
    Where did I aquire this information, easy, I measured it myself.......
    [/COLOR]
    Maybe this is why there is confusion; valves extend below the bottom plane of the head surface, but the pistons are cupped.
  11. Oct 30, 2013 at 2:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the 3.4L is non interference..so are 7mgte, 1jz, and 2jz..wouldn't be surprised if most Toyota motors are.
  12. Oct 30, 2013 at 2:27 PM
    BradyT88
  13. Oct 30, 2013 at 2:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Twin supercharger?? wow odd..
  14. Oct 30, 2013 at 2:29 PM
    BradyT88
    At 14:15ish I think he scared that black car:rofl:
  15. Oct 30, 2013 at 2:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Oct 30, 2013 at 2:50 PM
    rctoy
    konstantenos
    Pocatello Idaho
    ALL data says its a valve bender but its been wrong befor so ill just take that as a fuck yeah.. and not worry about it..
  17. Oct 30, 2013 at 6:04 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  18. Oct 30, 2013 at 6:06 PM
    BradyT88
  19. Oct 30, 2013 at 6:08 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yea Ben, Nelson does some sweet work!
  20. Oct 30, 2013 at 9:27 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Monte, looks like I may end up in your neck of the woods this summer. Got a verbal offer from a company to go work in Casper.
