Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Nov 8, 2013 at 7:13 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    My asus mother board took a shit and continues to be a pain in my side
  2. Nov 8, 2013 at 7:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Laptop problems..
  3. Nov 8, 2013 at 7:21 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I've had my laptop for a year and a half now, still no issues and runs everything just fine. There's nothing wrong with laptops Monte! Haha
  4. Nov 8, 2013 at 7:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    they suck far as im concerned. they never last..
    Both my Desktops are made of stuff almost 6 years old..my only issue is im out of hard drive space on my C:\ Drive...which is easy to fix...get another hard drive..done! :p see you do that to your Laptop..i mean..yea you can..but..i can hold 8...haha
  5. Nov 8, 2013 at 7:27 PM
    PcBuilder14
    Brent
    Nor Cal
    I don't get it, they last just as long as desktops do for everybody I know? :confused:
    My laptop can hold two internal hard drives and up to 3 external drives the way it is now. I don't need that many hard drives though, that's what a solid state and a 2 terabyte hard drive is for ;)
    Why you would want 8 separate hard drives is beyond me.
  6. Nov 8, 2013 at 7:27 PM
    BradyT88
    BradyT88 Well-Known Member
    Nice! That case looks familiar. haha I have an Antec 900.
    Here's mine:
    I had issues with these little guys overheating when I cranked up the voltage on the cpu during overclocking so I added some heatsinks.
    Everything barely fits on that micro ATX board. haha
  7. Nov 8, 2013 at 7:29 PM
    PcBuilder14
    Brent
    Nor Cal
    Can't wait to build myself another desktop someday...
  8. Nov 8, 2013 at 7:30 PM
    BradyT88
    I'm rocking a 17" ASUS laptop. Can't take a desktop to Iraq with you really. haha Had it for like years and use it pretty solidly every single day. Still works just fine.
    It has two 500GB hdd's in it and could fit a 3rd if I pulled the CD drive.
  9. Nov 8, 2013 at 7:31 PM
    BradyT88
    I was going to drop about $2-$3K into a BAMF desktop when I got home from Iraq. Instead I bought a Taco and dump all my money into it. haha
  10. Nov 8, 2013 at 7:35 PM
    PcBuilder14
    Brent
    Nor Cal
    I currently just have a internal and external 500gb hard drive each. Probably have to upgrade the internal one to a larger one at some point. But I couldn't have a desktop right now. As much as I travel and the fact that I'm on the third floor of the dorms, it just makes more sense. Once I get my own place I'll sit down and build myself a nice desktop. But for now my Alienware serves me well :)
  11. Nov 8, 2013 at 7:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This sounds a lot like what you are going thru right now with the music career.
    Here is what my night is about. :eek:
  12. Nov 8, 2013 at 7:51 PM
    BradyT88
    Is that a tweeter? I think I had/have a set just like that. Never ended up using them in my car though.
  13. Nov 8, 2013 at 7:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha yea...pretty much
    And nice! Cutting huh??
  14. Nov 8, 2013 at 8:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, a tweet. Part of the components I am installing.
    I prefer to label this as "fitting". :D Fortunately, the hole was already there. Just had to massage it a bit to get the tweeter to fit it.
  15. Nov 8, 2013 at 8:22 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Nice Mike! audio upgrades are always good :cool:
  16. Nov 8, 2013 at 8:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Marc. My audio guru, Montezuma says it will be awesome. I'll let you kno. :p
  17. Nov 8, 2013 at 8:37 PM
    SconnieHailer
    Marc
    cant go wrong with Alpine typeR man. :cool:
  18. Nov 8, 2013 at 8:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :woot:
  19. Nov 8, 2013 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :woot:
    Can't wait for you to finish!
    For what?
  20. Nov 8, 2013 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea then you get in to tolerances..im sure most of those parts are 10-15%...so there is a +/-10-15% error in them..
    so yea..probably not the most accurate thing..but works. 73Âş would be plenty hot..
