Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Nov 26, 2013 at 2:33 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    jerry has an awesome vid where the truck is lifted in a couple seconds on the ground
  2. Nov 26, 2013 at 2:36 PM
    BradyT88
    BradyT88 Well-Known Member
    Nitrogen isn't really supposed to be affected by heat plus it was doing this to us when my vehicle had been in the garage all day not moving. I thi k it has to do with where it stops in the lift. Like I was saying above how I can adjust my lift just by bouncing the vehcile up and down...
    You are supposed to have the full weight of the vehicle on the shock when adjusting them it says.
  3. Nov 26, 2013 at 2:42 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    :thumbsup: Just wondering.
  4. Nov 26, 2013 at 2:47 PM
    BradyT88
    I almost wonder if our rigs are too heavy for ORI's... the book says 600 psi max and we barely achieve lift at 600 psi... it says about 280 psi for a 4500 lb vehicle but we are still on the bumps at 280. Haha.
    JW said Jerry hasn't used a gauge to fill any of his. They just fill them til they look right.
  5. Nov 26, 2013 at 2:48 PM
    Manwithoutaplan
    ID
    So just one question where in idaho was that lava rock run ??? ^
  6. Nov 26, 2013 at 2:55 PM
    Manwithoutaplan
    ID
  7. Nov 26, 2013 at 3:17 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  8. Nov 26, 2013 at 3:24 PM
    BradyT88
    With the gauge on there while you bounce it up and down you will see the pressure go up and down as well. The increase in pressure is what slows the travel. When landing a jump for example that 700 psi at ride height can peak as high as 5000 psi. There is friction and heat involved but N2 has a mich smaller thermal expansion coefficient than say CO2 or oxygen so it doesn't expand as much at as temps increase.
  9. Nov 26, 2013 at 3:37 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    :rofl: hahahahaha
    That is too funny. first I've sent that
  10. Nov 26, 2013 at 3:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Damn straight :cool:
    Good to know.
    Idk how they do it. I had mine filled at the local Pepsi plant haha
    Whhhaaaaa?? Everyone else been saying they good for 1500psi...
    Or is that 1500psi max including compression of the shock? In which case..weak sauce.
    But they are rated 1900lbs each too so kinda doubt your truck is too heavy for it.
  11. Nov 26, 2013 at 4:24 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That is very odd. And doesn't sound quite right. So one hard landing and you ride height drops an inch and if your suspension droops all the way you gain an inch on the fly?
    That's odd that it doesent go right back to where you had it set.
  12. Nov 26, 2013 at 4:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    from what i understand the ride height is controlled in a separate chamber from the shock dampaning, and that the psi controls the height
    if so, it might not necessarily be uniform, if it's entirely controlled by pressure
  13. Nov 26, 2013 at 4:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right so shouldn't that pressure stay relatively the same? Only that could really change it is heat. But as Brady pointed out, nitrogen doesn't get effected by heat hardly
  14. Nov 26, 2013 at 5:42 PM
    BradyT88
    Yeah. Air is about 70% nitrogen.
    On the ORI's the upper chamber control ride height and shock rebound while the lower dampens rebound so the 2 chambers works against each other.
  15. Nov 26, 2013 at 5:44 PM
    BradyT88
    JW and I are kind of in between that the ORI's are always going to have that ride height play in them and that the air shock just isn't as static and fixed as a coil spring or that they will even out better as the seals break in.
  16. Nov 26, 2013 at 5:54 PM
    BradyT88
    Yeah. The helium thing just seems odd. Haha
  17. Nov 26, 2013 at 6:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    helium filled air shock??
  18. Nov 26, 2013 at 6:11 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    EDIT: Fuck the internet and websites that won't let you steal their pics.
  19. Nov 26, 2013 at 6:42 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  20. Nov 26, 2013 at 6:45 PM
    SconnieHailer
    Marc
    haha, make that truck size, give it a cockpit and go anywhere!
    kinda like this
