Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 1, 2013 at 2:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    32s. 265/75r16s
  2. Dec 1, 2013 at 2:36 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    fuck all of that noise
    I'm in 4lo more often than not. But ya. Lock and unlock for each obstacle
  3. Dec 1, 2013 at 2:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You have to be in 4lo to move
  4. Dec 1, 2013 at 2:52 PM
    BradyT88
    BradyT88 Well-Known Member
    About like JW before the S/C. Haha. He said before the S/C his skinny 36's would bog the motor down bad while crawling and snow wheeling.
  5. Dec 1, 2013 at 2:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh ya I bet! Was it sweet to see in person?
  6. Dec 1, 2013 at 2:58 PM
    BradyT88
    And I just realized that makes Mark extra screwed because JW's 4 bamger puts out more power and torque (even before the S/C), JW has a manual so the 1st gear is much lower, 2nd gen tcase is also geared lower and he has 4.88's to Mark's 4.56's. When JW told me that I'm not sure if he was saying with the 4.7 compound low also engaged or not.
  7. Dec 1, 2013 at 3:05 PM
    BradyT88
    It was pretty sweet! It is interesting to see the tires kind of stutter like they do when it lugs up something. The video I posted in his and my build threads of him trying to cross that log kind of shows this.
    The amount of diff clearance he has is insane! Just blew my mind the whole time I followed him around!
    I think I am sold on his tires again! With them I can keep my wheels and not have to worry about bead locks really, running a 12.50 tire on an 8" wheel and he said he has about 36,000 miles on them and they still look brand new and he uses them in the lava rocks. My tires have like 12,000 miles on them and the tread is shot...
  8. Dec 1, 2013 at 3:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea mark is screwed haha needs to buy the sc for his in the FS section.
  9. Dec 1, 2013 at 3:13 PM
    BradyT88
    Mark has a 29.11:1 crawl ratio right now.
    JW has a 49.48:1 not counting the crawlbox.
    That is almost twice the crawl ratio and he said it would bog down bad on him with his tires...
    With the crawlbox he has a 232.56:1 crawl ratio.
    For refence a factory 1st gen manual (Monte and Ben) have a 35.80:1; a factory 1st gen auto (Cody) has a 26.17:1; a factory 2nd gen (Monte's Dad and Andy) have a 33.70:1; and I have a 44.09:1.
  10. Dec 1, 2013 at 4:13 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I also weigh less.
    But woohoo!!! I'm screwed!
  11. Dec 1, 2013 at 4:18 PM
    BradyT88
    True. He is heavier, but how long til you add all that armor as well?
  12. Dec 1, 2013 at 4:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mark needs armor bad haha he doesn't even have a front skid
  13. Dec 1, 2013 at 4:34 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Neither do I. I had to cut the last one off with a torch it was so mangled up. I want to build the next one out of UHMW but that shit is hard to find locally.
  14. Dec 1, 2013 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm gonna make my bell skid out of that stuff. Found some for pretty good prices online.
  15. Dec 1, 2013 at 4:49 PM
    BradyT88
    That would be awesome! That stuff is supposed to slide across rock like a bar of soap in an inmates hands at shower time!
  16. Dec 1, 2013 at 5:10 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    You spent some time in county too huh? :eek:
    I also thought about using kevlar/carbon fiber/UHMW laminate to increase rigidity and reduce weight. I still have some leftover material from the uparmor taco project...I'm just out of motivation after working on my wifes duramax all weekend.
  17. Dec 1, 2013 at 5:13 PM
    BradyT88
    Negative! My record is spotless! hah
  18. Dec 1, 2013 at 6:09 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Let me know what it runs ya. Might request you make me one at the same time if you're making one
  19. Dec 1, 2013 at 6:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not that cheap..haha not cheaper then like bud builts anyways. I think..have to look at UHMW again..but yea you bet.
  20. Dec 1, 2013 at 6:20 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Fack. Shall see
