Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 3, 2013 at 12:17 PM
    BradyT88
    BradyT88 Well-Known Member
    Are yours 4.5" BS? and how close were yours to fitting, less than an 1"?
  2. Dec 3, 2013 at 12:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes factory 1st gen rims are 4.5" give or take
  3. Dec 3, 2013 at 12:18 PM
    BradyT88
    Mine still are, but I have maximum up-travel compared to you guys. My 33's have been beating back my firewall for me 1 jump at a time. haha
  4. Dec 3, 2013 at 12:20 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    back tires up on something, check!
    and ya mine are 4.5. i honestly dont remember how close it was. it was dark and cold haha. i hope that extra .5" will help it
  5. Dec 3, 2013 at 12:20 PM
    BradyT88
    So are the wheels going with your 33's, 4" BS or 3.75"? If 4" it is going to be close for Mark, unless his wheels damn near fit. Although your tires are about 1.25" wider on each side of the wheel! So if the tire was preventing him from mounting Mark's tires and not the wheels, he will need like 1" spacers or more.
  6. Dec 3, 2013 at 12:22 PM
    BradyT88
    :facepalm: Just read back in Mark's post and saw that he said his wheels were 4.5" BS and that it was the wheel hitting the steering arm, so hopefully that half inch does it:pray:
  7. Dec 3, 2013 at 12:23 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'm too lazy to go back and look, are they 15"s or 16"s?:eek:
  8. Dec 3, 2013 at 12:25 PM
    BradyT88
    15's.
  9. Dec 3, 2013 at 12:51 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I did the best i could with that even modded my LCA's but with my drop bracket i still cant get into factory specs..
    When i go wider it'll have nothing to do with backspacing:D
  10. Dec 3, 2013 at 2:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no it doesn't. Your over thinking back spacing. can't think of it like offset.
    Back spacing is back spacing. No matter how wide. Its still 4''.
    my current ones are 4''
    the 35s are gonna be 3.75
  11. Dec 3, 2013 at 2:04 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    thats exactly what I thought. i didnt need to say anything becuse brady kinda realized it...but ya. BS is BS,
  12. Dec 3, 2013 at 2:18 PM
    BradyT88
    Backspacing and offset are 1 in the same they are just measured differently. If you go to a different width wheel, then yes you can't really compare the backspacing between the two, but if the wheel width is the same you can, because the offset and the BS of same width wheels will have the same difference between them.
    Let's say both of your wheels are 8" wide wheels. If you have 4" BS on one, it will have -12.7mm offset. The other with 3.75" BS will have a -19.0mm offset. The difference between 19.7mm and 12.7mm is 0.25" just like the difference in the BS and the wheel has been pushed 0.25" further out causing it to rub on the cab more.
    Going to a wider wheel with the same BS as a slimmer wheel will also push the tire out farther causing it to rub the cab more. Again, an 8" wheel with 4" BS has -12.7mm offset and a 9" wheel with 4" BS has a -25.4mm offset. This time the wheel will stick out 1" farther than on the 8" wheel, but the difference in offset is only 0.5".
    I'm sure you've seen this example before:
    The only thing I don't understand exactly, is the center of an 8" wheel should be 4" right? So why is 4.5" the 0 offset spot for an 8" wheel? I would think 4.5" would be 0 offset for a 9" wheel.
    Edit: Got it. Apparently when they list wheel width, the lip of the wheel is not included, but when measuring Backspacing and offset it is and 8" wheels are really 9" wide from lip to lip so the 0 offset is 4.5" instead of 4".
  13. Dec 3, 2013 at 2:27 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well cool! this guy out of nowhere just messages me, he needs the bumper and grille from the wrecked taco shipped asap. so im going to wrap them up and ship em out like tomorrow and make some extra cash. they sold themselves from that thread I had haha.
  14. Dec 3, 2013 at 2:33 PM
    BradyT88
    Nice! Can't complain about extra monies!!!:woot:
  15. Dec 3, 2013 at 4:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Like i said..back spacing is backspacing. much less confusing then offset.
    gonna pay me then? :p
  16. Dec 3, 2013 at 4:10 PM
    BradyT88
    Yeah, I prefer using backspacing to offset, mostly because I prefer using inches to mm. haha But that doesn't mean that what I said above it wrong. Less backspacing = more cab rubbing but less frame rub because it moves your tire farther out from the steering pivot point so it has a bigger sweep basically.
  17. Dec 3, 2013 at 4:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i know..
    But measuring is also much easier for the common person. And its the same rim to rim.
    thats why we use it more.
  18. Dec 3, 2013 at 4:44 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh come on lol. Help a brother out. I'll pay ya when it comes closer to me getting then. Can't we jus say they are on lay away haha.
    As of now I am confirmed buying your tires. There is just a distance issue at the moment.
  19. Dec 3, 2013 at 4:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    than*
    cmon, monte. I believed in you.
  20. Dec 3, 2013 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha lay away? what if some guy come's up to me and offers full payment tonight? :p
