Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 14, 2013 at 5:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    study study study then take a break
  2. Dec 14, 2013 at 5:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i have 2 more finals, on tuesday, the i get one :)
  3. Dec 14, 2013 at 6:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ok. i get on now
  4. Dec 14, 2013 at 6:12 PM
    BradyT88
    BradyT88 Well-Known Member
  5. Dec 14, 2013 at 6:28 PM
    BradyT88
  6. Dec 14, 2013 at 6:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea buy like hardly any 16.5 rims.
  7. Dec 14, 2013 at 6:35 PM
    BradyT88
    At that point I would buy some like Logan's with bead locks and all.
  8. Dec 14, 2013 at 6:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Dec 14, 2013 at 6:38 PM
    BradyT88
    Username
  10. Dec 14, 2013 at 7:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh haha
    yea that would be cool
    also..the game Titans...looks epic.
  11. Dec 14, 2013 at 7:31 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  12. Dec 14, 2013 at 7:42 PM
    BradyT88
    I never said they weren't tough. In fact I'm pretty sure they will be my 1st choice if I have to get new wheels, at the moment I just see no reason to get new wheels. Mine do fine and beadlocks won't be all that necessary when stuffing a 12.50 on an 8" wheel.
  13. Dec 14, 2013 at 10:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :facepalm:
    It is very tiresome when you continue to mangle, mis-quote, exaggerate and otherwise try to re-write history.
    For the record, here is what I wrote:
    You are normally a very bright guy, are you sick today? Maybe a lack of sleep. :notsure: Or maybe its just time for an eye exam. :)
    It's a sign a affection. It beats the hell out of being ignored.
    :rolleyes:
  14. Dec 14, 2013 at 10:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    bout time you dropped in.
    No i have logic to that. Im saying to get in a wreck to be Total worthy, have to be a pretty big wreck..in which case..a steel bumper does more damage then good in that situation..
    make sense?
  15. Dec 14, 2013 at 11:07 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is where we disagree. That statement applies only to newer vehicles.
    The kelly bluebook says my truck is only worth $5,000. But if it cost anywhere near that amount to fix it, the Ins Co will total it.
    It takes very little damage to reach the 5K mark these days.
    Lets use your Dads truck for comparison. Same 5K in damage, will not be totaled. It isn't because of the amount a damage, its because of the cost to repair compared to the estimated (Kelly Bluebook) value/cost to replace.
    In the case of older vehicles,in the Ins COs eyes, it is way to easy to chose the replace option and just pay out the 5K. If I can do anything to reduce the damage for a small accident (remember, 5K damage is easy to reach, and 5K is all they will pay) then that is what I want to do.
    make sense?
  16. Dec 14, 2013 at 11:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right. I agree with that..
    But thats only going to help you in minor accidents..if you have a major wreck..like someone slams into your rear and you get driven into someone infront at high speeds for whatever reason or T bone someone or whatever..the steel bumpers will most likely help bend your frame..resulting in an instant total call from the insurance company..
  17. Dec 14, 2013 at 11:16 PM
    BradyT88
    But in that case you are likely getting over $5000 worth of damage with the bumper or not...
  18. Dec 14, 2013 at 11:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not always..but probably.
    either way..i still agree getting bumpers is better..im just saying..they also transfer energy straight to the frame..so they don't make the truck invincible.
  19. Dec 14, 2013 at 11:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What you say is true but that was not what Ben's reasoning for getting the bumper was. And its not mine either and isn't what prompted my comments. Only you have linked "totaling" to getting a bumper for protection.
    Think of getting a bumper as preventative maintenance. Will it prevent an Ins. Co. from totaling it? No, not if the damage is greater than a certain threshold. But in circumstance that Mark mentioned, Yes, it may prevent it from being totaled. Especially when you consider the tendencies of the Ins COs.
  20. Dec 14, 2013 at 11:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Of course they don't. That is why I have a force field and carry laser weapons. :cool:
