Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 19, 2013 at 10:39 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    LOL at Nevada
  2. Dec 19, 2013 at 10:43 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    we use white cheese curds here, taste way better. If you go to Montreal, they have poutine shops that make all kinds with different meats
  3. Dec 19, 2013 at 11:29 AM
    lunchboxhero
    lunchboxhero Out for a rip eh!
    Aleks
    Boise, Idaho
    That looks.... GUHHHH WANT.
  4. Dec 19, 2013 at 11:37 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
  5. Dec 19, 2013 at 11:41 AM
    Rob720
    Rob720 Well-Known Member
    Robert
    Boise, ID
    12' DCSB Super White
    OME 885's with Dakar leafs, Nitrocharger shocks, Pelfreybuilt HC rear bumper, swing gate tire carrier and rotopax, OBHS
    Got it back from alignment yesterday and it drives better! Wheel is straight again and it doesn't seem to pull at all. I still have a growling or vibration. I don't think it is coming from the driveline though as it is always present. alignment shop said it was the tires but I had those before the lift so I disagree as it didn't feel that way before. It isn't consistent with the tires rolling either. The noise is intermittent but sounds the same each time it appears. Gonna check the bearings today and see if there is anything going on. But it feels like its coming from my passenger front. Maybe paranoid but don't want to mess anything up. Suggestions on anything I may be overlooking?
  6. Dec 19, 2013 at 11:44 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you a 4x4? If you engage 4WD does the noise/growling go away?
  7. Dec 19, 2013 at 3:01 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    let me retract previous statement...mainly because i give no fucks
    darker dot, slightly lighter. wow. i see no way at all this has anything to do with bsu...
  8. Dec 19, 2013 at 3:53 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    "more educated" doesn't necessarily mean smarter.......
    :cool:
  9. Dec 19, 2013 at 5:40 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i want to make that
  10. Dec 19, 2013 at 6:48 PM
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    well hey there again. Back in big wonderful wyo for a few days for break... it's good to be here, mountains are just as grand!
  11. Dec 19, 2013 at 7:20 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  12. Dec 19, 2013 at 7:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Boom. In co
  13. Dec 19, 2013 at 8:13 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I was at the local skihill lodge having lunch one day and this skibum comes up to me baked as shit and says "are those graaaavy cheeeeeese fries man?" I bursted out laughing
  14. Dec 19, 2013 at 8:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :thumbsup: Any dramas?
  15. Dec 19, 2013 at 8:26 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Possible snow tonight and tomorrow! You gonna hit the mountains tomorrow Mike?
  16. Dec 19, 2013 at 8:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hey Phil, how are things going?
    Yeah, we are supposed to get a little white stuff overnight. Very unusual for us. Unfortunately, I have to work tomorrow so can't get out till the weekend. Tomorrow's commute should be interesting tho. I think I will drive the armored vehicle tomorrow. The corolla will remain parked in the garage. :cool:
  17. Dec 19, 2013 at 8:37 PM
    tacomakid96
    Phil
    Out n' about
    Oh I can't complain things are good pretty good! To bad you have to work, but you'll probably have more close calls on your commute to work anyways haha, drive safe tomorrow buddy!
  18. Dec 19, 2013 at 8:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Haha, western washingtonians have no clue when it comes to driving in snow. It'll be exciting.
  19. Dec 19, 2013 at 9:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This color is growing on me. :cool:
  20. Dec 19, 2013 at 10:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nope. Pretty chill. Killer sunset. Want to stop and take a photo but didn't.
    I think pretty much nobody does except in wy...why? Cause they don't plow much in wy so you have to know haha
