Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 24, 2013 at 7:47 PM
    BradyT88
    BradyT88 Well-Known Member
    The snow would just turn to ice under my tires pretty much instantly when they spun and the fact that both rigs were trying to go up hill didn't help me any... this was after I ripped the slider off and right before we got the hi-lift out. Just a small bump.
    http://youtu.be/WAt_MSRdTlU
    and Nicole doing donuts!!!
    http://youtu.be/5G62yUsp8_I
  2. Dec 24, 2013 at 7:57 PM
    BradyT88
    The rear two frame plates are still attached to the frame via the bolts, and I ripped the sliders off their frame plates.
    Notice how the 1 frame plate is still there on the right of the pic (it is the front one that basically wasn't attached to the frame and the other two legs are missing their frame plates because they are still bolts to the frame. The welds literally broke before the bolts did.
  3. Dec 24, 2013 at 8:07 PM
    BradyT88
    Just out of curiosity, since you are an ME, what is the breaking point of a couple of course thread 1/2" bolts? Like the point they would either sheer or strip the nuts off the bolts. I think Cameron's are grade 5 and he had 2 on each leg. I have 3 grade 8's on each of my legs.
  4. Dec 24, 2013 at 8:19 PM
    BradyT88
    I see. I just asked, because personally I just can't imagine it is that much lower than the welds themselves, especially since you can only weld the sliders to the frame plates themselves so much.
    In Cameron's case, had those two bolts on the front leg actually been holding on, I don't think I would have ripped the slider off or at least not as easily as I did anyway.
  5. Dec 24, 2013 at 8:48 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    Merry Christmas fellows!
  6. Dec 24, 2013 at 8:53 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    x2 Merry Christmas guys
  7. Dec 24, 2013 at 9:02 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Oh ya. Your welding job is really something to admire. Please teach me to weld better
  8. Dec 24, 2013 at 9:44 PM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    As soon as I heard it, I knew exactly what had happened...
    For the record, I have lifted the whole side of my truck up by the sliders with a Hi lift and did fine.....
  9. Dec 24, 2013 at 9:46 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Controls for the win
  10. Dec 24, 2013 at 9:48 PM
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    Oh yeah she did! :) apparently when she used to live in Utah she used to stalk any of our wheeling trips I put up on Facebook.... she had a lot of fun
  11. Dec 24, 2013 at 9:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Well, looks like you'll be honing your wiring skills.
  12. Dec 24, 2013 at 11:34 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I got stuck :p in the double cab haha just ran 1.5 mile to the hi way to get picked up
    Frankenstein is gonna have a rescue mission tomorrow.
  13. Dec 24, 2013 at 11:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do it. Don't bother with the shit connector. You won't be able to set it up right with out special crimpers anyways and they fucking suck anyways. Just get some new connectors.
  14. Dec 24, 2013 at 11:38 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Where did you get stuck?
  15. Dec 24, 2013 at 11:40 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    merry christmas guys!
    Monte, i got a solar panel like yours that plugs into the truck!
  16. Dec 24, 2013 at 11:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bench. Just a road. Was out with G shooting photos. No good tires and ground clearance means stuck in a snow drift. Nothing bad.
    Nice! I'm gonna wire mine up over break. How big is it?
  17. Dec 24, 2013 at 11:44 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Merry Christmas my not quite PNW bitches
  18. Dec 24, 2013 at 11:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    pics. must. pics.
  19. Dec 24, 2013 at 11:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Merry Christmas present to myself :D
    So 33s going back on tomorrow!
  20. Dec 24, 2013 at 11:47 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Not very big. 24"X8" maybe
