Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 25, 2013 at 8:42 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    power cables yes it should..hose..no idea.
  2. Dec 25, 2013 at 8:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Duty cycle ratings presented in terms of minutes is misleading information. To be meaningful, duty cycle should be presented as a percentage number.
    For example, the best compressors (read: expensive) have a 100% duty cycle. Which means they will run continuously and never shut down because of heat.
    Without a recovery time, the information smittybilt is providing is somewhat meaningless. But even so, if it is a 50% duty cycle, it would take 40 minutes to recover from the heat. If it runs long before shutting down.
    I am a bit surprised by the 40 minute number. I'm guessing the reality will be less than that. How much less will depend a lot on the tires size, how high a pressure you put in the tire and whether it is 32* or 85* outside.
  3. Dec 25, 2013 at 8:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Exactly. I was surprised as well by there not being a %. Maybe I'll have to do some more digging on sites other than Amazon to find specs. Even so, if it takes 5 min a tire even at half the advertised "duty cycle" it would fill all 4 before shutting off
  4. Dec 25, 2013 at 9:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    5 mins a tire...horrible.
  5. Dec 25, 2013 at 9:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rolleyes: sorry I won't be able to fill a 35 in one minute. Better than begging each time.
  6. Dec 25, 2013 at 9:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    How much $$ for ...not horrible? :cool:
  7. Dec 25, 2013 at 9:23 PM
    BradyT88
    BradyT88 Well-Known Member
    It takes me almost 20 minutes to fill up my skinny 33's with my ARB and it puts out more air than a 480C.
  8. Dec 25, 2013 at 9:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    from 10 to 40 psi? Or ???
  9. Dec 25, 2013 at 9:28 PM
    BradyT88
    20 to 50 psi.
  10. Dec 25, 2013 at 9:28 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well it'll just take me a ton of time and we might as well just plan eating lunch around me airing up
  11. Dec 25, 2013 at 9:29 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Holy fuck 50?? I go from like 15 to 32ish
  12. Dec 25, 2013 at 9:36 PM
    BradyT88
    My Tacoma is heavy dude! I have been getting lots of side tread wear so I pump them up to 50 psi in the summer to wear down that center tread. Supposedly I should get better fuel economy that way too. In the winter I drop them down to 25 psi and just leave them there. I typically wheel at 20 psi though.
  13. Dec 25, 2013 at 9:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    15 to 40 for me. about 90 seconds per tire.
    :rolleyes:
  14. Dec 25, 2013 at 9:43 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    90...seconds. Sounds really good!
    And what's the eye roll for?!
  15. Dec 25, 2013 at 9:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I used to run my 33x10.5 BFGs at 32 and found 40 much more to my liking. Better mpgs I think and maybe a little more power too. :notsure:
  16. Dec 25, 2013 at 9:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Who's Miata? At the dealer?
  17. Dec 25, 2013 at 9:51 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well hell. Maybe I should set them higher closer to 40 now?
    Same for the 35s ya think?
  18. Dec 25, 2013 at 9:59 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Run the tire pressure at whatever gives you even tread wear. The 35" MTR/Ks was in the low 20s
  19. Dec 25, 2013 at 10:11 PM
    BradyT88
    Hmm... I wonder if mine will do 15 to 40 in 180 seconds them. That sounds about right. I did 1 tire from 20 to 50 in 5:05 and 20-40 in 3:20 which is 200 seconds... so yours is more than twice as fast as mine it looks like. I think my hose and ARB gauge slow down fill up though...
  20. Dec 25, 2013 at 10:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    350 for a 20lb co2 kit..or less I think for a fixed regulator.
    Good god I couldn't do that anymore.
