Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 25, 2013 at 10:17 PM
    skygear
    skygear                    
    Monte - I noticed in the LED thread you had some side mounted light bars. What were they? Do you still have all the LEDs you posted back then in addition to the LF HID's?
  2. Dec 25, 2013 at 10:18 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    should probably figure out the correct psi with a chalk line or something then ha
    or 25 with this gift card...seems like a no brainer to me, I can wait 20 min, that 300 can go right to trip funds.
    ALSO got a gift card to orilleys from the grandparents...SPARE PARTS!!!
  3. Dec 25, 2013 at 10:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I do.
    They are Blitzpro hawk 21s bars. Great flood lights.
    My light forces are just 100w halogen. My Hellas are 55w hid.
  4. Dec 25, 2013 at 10:24 PM
    skygear
    skygear                    
    Ah, is it all in your build thread to read through?
  5. Dec 25, 2013 at 10:29 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    :popcorn:ing for when I set my 6" LED's up
  6. Dec 25, 2013 at 10:29 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    imo tapping into that fuse panel is a pain. I would try monte's grounding switch method for your lights.
    run power from the battery to the lights then the ground wire into the cab to the switch then the ground from the switch somewhere convenient in the cab, like the 4wd computer bolt.
  7. Dec 25, 2013 at 10:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Your looking at $400+ by the time you add in shipping and you'll also need an air chuck of some soert. But...it will be fast.
  8. Dec 25, 2013 at 10:37 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ive don't the fuse tap too, don't like it ha. add a ring and just put one more loop on a bolt on the battery terminal?
  9. Dec 25, 2013 at 10:41 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    #bulhas
  10. Dec 25, 2013 at 10:41 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    playing with the camera. me likey. should be fun to play with in japan.
  11. Dec 25, 2013 at 10:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. All there. Just go to the OP. everything is linked.
    16 gauge is fine for one light.
    For just the one you won't need a relay. Fuse it right and it'll be fine with just a switch on the ground.
    Don't get power tank
    Look at wheelers The Source kits. What mine is. Cheaper and just as good.
    373 for 20lb with adjust able regulator. 291 with fixed 150psi regulator.
  12. Dec 25, 2013 at 10:48 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I really don't know the first thing about running an air system...but I have a 7 gallon air tank sitting around, right now it only has a regular tire inflate hose and a psi gauge, but is there any economical way to maybe mount it somewhere on the truck and run a hose to attatch to the air compressor and a hose out to a tire fill end attachment?
  13. Dec 25, 2013 at 10:49 PM
    skygear
    skygear                    
    What bar did you get? You do not have a build thread.
  14. Dec 25, 2013 at 10:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Soldering gun is different. I'd get one for stuff like this. Keep the iron tho for circuit boards and super small wire. A gun will melt pcb board as they are 100w and 150w
    I'd wire the power wire to the battery. Why? Because almost all the power you can tap into in the truck..is ignition source. So it'll only have power when the truck is on.
    Run it to the bed under the frame rail and up though the bed and into the box. Use wire loom and silicon and rubber hose around edges of cut metal.
    Run your ground wire through the passenger side grommet like the cb wire(btw don't run the power wire by the cb cable) and then too your switch. Then switch to the ground near by.
    Will take a lot of wire.
  15. Dec 25, 2013 at 10:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tanks do t help that much for filling tires. More for air tools.
    Only good place for mounting them is where the stock spare goes. And if it hangs lower then 7" then not really worth it.
  16. Dec 25, 2013 at 10:54 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    dam. was hoping I could use that for something. oh well
  17. Dec 25, 2013 at 10:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I used my 6" reverse LEDs a lot tonight haha had to back out a half mile haha
  18. Dec 25, 2013 at 10:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could get a tool box like Ben and mount it in there if ya want.
  19. Dec 25, 2013 at 10:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    need to get some of those suckers
    wait where is ben putting them without a rack or something to hold them? The bed rail?
  20. Dec 25, 2013 at 10:57 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    absolutely not worth it. my rack wouldn't fit, and my bikes wouldn't fit,
