Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 25, 2013 at 10:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    His tool box. A the bed will cut off most the light. But be a good light none the less
    Haha well then
  2. Dec 25, 2013 at 11:01 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    oh ya, forgot he got that thing
    im tellin ya man, I still need to make one of those tripod light poles. can hold the light up when I don't have the rack in (like right now)
  3. Dec 25, 2013 at 11:03 PM
    skygear
    skygear                    
    AH! Started on my 360º lighting this evening.
    5ajusabe_cb778d7f955d9c44a2a0e8b98ba4990082647457.jpgtuzeje9y_9c71a2662855b580b81655cd23ce57440c125118.jpg
  4. Dec 25, 2013 at 11:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    mont when does the fender cutting and firewall tubbing start?
  5. Dec 25, 2013 at 11:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    how's the outiput on the 6"?
  6. Dec 25, 2013 at 11:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I love those lights. So bad ass and handy.
    You could make a mount that's stays in the truck. Or just leave a quick disconnect on the light like mine so you can take it off with the rack.
    Not for a while now..grant and I are gonna go camping this weekend and I won't be able to finish the by them. So after mike leaves.
    Not a big fuse. It's 6w yea? So only need 2 amp or so. A 4 would be fine too. Think 2.5s are out there.
    You always need a fuse too.
    Make sure you CHECK the switch. Some label stuff odd and all so use a continuity meter to check which prongs are which.
    Should be good man. I expect good things....
  7. Dec 25, 2013 at 11:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty good nothing epic. Great for close range stuff. I use em in my mirror lights. But I'm gonna redo mine with dual row LEDs soon..:spy:
  8. Dec 25, 2013 at 11:21 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    okey dokey! where you guys going camping at?
  9. Dec 25, 2013 at 11:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When are you planning on being back from camping?
  10. Dec 25, 2013 at 11:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Big horns probably
  11. Dec 25, 2013 at 11:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sunday I bet or Saturday.
  12. Dec 25, 2013 at 11:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Can you be a little more precise please. Trying to figure out if you will be out camping when I get to powell. :eek:
  13. Dec 25, 2013 at 11:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice man.
    And you don't have a meter??? Seriously?
  14. Dec 25, 2013 at 11:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can't as I have no real plan yet haha but I'm sure we will be back before you get there.
    Scared of hanging with my mom and aunt all day :p
  15. Dec 25, 2013 at 11:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think vice grips are going to help in this situation. :rolleyes:
  16. Dec 25, 2013 at 11:44 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    bens tool box is full of nothing but vice grips ha.
  17. Dec 25, 2013 at 11:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You didn't bring it?! That's an OSK item!
  18. Dec 25, 2013 at 11:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh? Really? What time am I getting there?
    and no...er, I mean...yes :eek:
  19. Dec 25, 2013 at 11:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They are nice ladies! Haha
    Idk when you getting there?
  20. Dec 25, 2013 at 11:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    After you get back from camping. :rolleyes:
