Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 10, 2014 at 9:57 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Holy shit haha
    My rims are only 4" BS. You'll need spacers.
    FUCK no haha not even REMOTELY close.
    More inside but also outside. Because at full lock when turning the outer lug comes into the a pillar and fire wall. Quite a lot. That's why you have to cut that part
  2. Jan 10, 2014 at 10:01 AM
    BradyT88
    BradyT88 Well-Known Member
    Hey Monte, can you measure how wide your tires are on the truck when you get a chance and try to measure how wide you are from outside edge of tire to outside edge of tire.
    Then Mark can meet up with this guy and measure the same by just throwing the front tires on real quick.
  3. Jan 10, 2014 at 10:02 AM
    BradyT88
    Dibs! ;) haha
    I can't run 15's...
  4. Jan 10, 2014 at 10:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I can.
    Need to figure this out ASAP. I gotta drive 400 miles extra to deliver these things..haha if I don't have to..be a nicer drive day
  5. Jan 10, 2014 at 10:09 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I know i would need spacers
    ok, was just checking. so i want to see how much i can actually turn with these things. i guess all the cutting will be determined by how far they stick out. in this case i want them in a bit more, because i have room to cut inside more, vs getting super close to the door hinge
    any other measurements i should take?
    good, go away. :D
    thats what im trying to do!!
  6. Jan 10, 2014 at 10:10 AM
    BradyT88
    Measure the BS on those wheels! and are they 10" wide wheels for sure?
  7. Jan 10, 2014 at 10:13 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    how exactly does one meause that?
    and i dont know for sure!
    also...this is absolutely beautiful!! love it!
  8. Jan 10, 2014 at 10:14 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Novel idea only moab calls my name and some one out there wants a pair of arb's in some 4.88 gears and they will pay me for it.
    Ill get my money back on the arb ill lose my time to install it. oh well..
    im lost what do you want dibs on..
  9. Jan 10, 2014 at 10:15 AM
    rctoy
    konstantenos
    Pocatello Idaho
    you fucking derp it's the distance from the back of the rim to the mounting surface of the rim..
  10. Jan 10, 2014 at 10:16 AM
    BradyT88
    Mark wants your MTR's so I was fucking with him. haha
  11. Jan 10, 2014 at 10:20 AM
    rctoy
    konstantenos
    Pocatello Idaho
    great now hes gonna measure with some sorta warped peice of cardbord:smack:
    and yeah i was gonna say what could you possibly use off of my truck for your LT second gen truck you bastard.
  12. Jan 10, 2014 at 10:25 AM
    BradyT88
    Better?
    Bigger tires ;) haha Can't run 15's on 2nd gens though...
  13. Jan 10, 2014 at 10:28 AM
    rctoy
    konstantenos
    Pocatello Idaho
    Much better and actually there is a guy in pocy that has a second gen and has a set of 38's on 15's he runs. the wheel spacer he runs to do it is retarded though
  14. Jan 10, 2014 at 10:31 AM
    BradyT88
    I've seen it! Nothing like having negative backspacing. haha
  15. Jan 10, 2014 at 10:35 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    K I figured that's how it was done
  16. Jan 10, 2014 at 10:56 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    That was a BAD movie
  17. Jan 10, 2014 at 11:46 AM
    BradyT88
    450lbs worth of steel according to the sales receipt...
    Those 4'x4' sheets just barely fit in my bed with the tail gate down.
    Squat much... I may have to talk to deaver about getting more leafs for this leaf pack... I think once we get the frame plates and the shocks in I will be at factory ride height in the rear or lower...
    I took the flare off to see what it looks like under there and so we can see if we will have to trim the bedsides at all for full stuff. I already know I'll have to trim the flares
    That damn salt is already making the bedsides rust where the paint chipped off of them...
  18. Jan 10, 2014 at 11:54 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Are you building skids too?
  19. Jan 10, 2014 at 11:59 AM
    BradyT88
    No. I already have skids, and yes I may have bought a bit extra steel... haha
    1 sheet if for building the shock towers and the other is for plating and boxing the frame. Depending on how much steel I have left over I may just plate all the way to the front.
    That smaller sheet on top is the new bottom for my toolbox. My hi-lift fucked it up.
  20. Jan 10, 2014 at 12:07 PM
    lunchboxhero
    lunchboxhero Out for a rip eh!
    Aleks
    Boise, Idaho
    Mark, since I know you'll check this thread before anything else. Dinner tonight, Myself, you, Jordan, Zach and Myles are a maybe.
