Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 10, 2014 at 4:34 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It's not that, I don't mind cruising around in 4lo if people are cool. The dog somehow hangs on and just floats along for the ride. He did break my windshield once, but that was my fault for hitting a "dog chucker" (sharp ledge that kicks the tail high, aka wheel barrowing) at speed. He was ok, but since then I slow down with him in the cab.
  2. Jan 10, 2014 at 4:40 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Also I'm now satisfied hahahha
  3. Jan 10, 2014 at 4:41 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    yes you did, and i appreciated it very much. :thumbsup: i'll bring you a 12 pack of your choosing this year.
    i have since remedied the "sky scraper" of a bed rack:eek:
  4. Jan 10, 2014 at 5:18 PM
    BradyT88
    BradyT88 Well-Known Member
    :eek: What did he think of that?! haha
  5. Jan 10, 2014 at 6:19 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Yeah I was a little confused about the bed rack thing because I was on the other side of the crowd so couldn't hear. Figured he'd be more appreciative about getting it.
    And on a side note...
    I love my LED light bar, LED reverse lights, LED dome light and LED rock lights. :rofl:
  6. Jan 10, 2014 at 6:35 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    That's just it he's not at all, he is holding a grudge and didn't even send a photo like asked...
  7. Jan 10, 2014 at 6:42 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  8. Jan 10, 2014 at 7:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    He's not going to be able to use a long straight edge like that if the tire is mounted on the rim. The sidewall is going to interefere.
    Beside, pretty sure the backspacing measurement does not include that little lip on the rim. Really need to be inside that little lip. IMO, this is a beter technique unless you have a hard straight edge that fits inside the little lip. :eek:
  9. Jan 10, 2014 at 7:59 PM
    BradyT88
    You are correct and that is why I posted the cardboard one first. haha
  10. Jan 10, 2014 at 8:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    haha, that is what I figured but someone :gossip: is uncomfortable with warped cardboard.
    Mark, take something you can easily trim to size. :)
  11. Jan 10, 2014 at 8:29 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i just had the guy measure it for me since its a long drive out there and monte assured me that there would be nothing gained from me test fitting the tires.
    it came out to be like 3.5
    im so on the fence about this now. monte is convinced that there is no way to make it fit because i cant cut enough out to keep them from rubbing. im just trying to figure out if i want to risk it and if i can cut enough to make it work
  12. Jan 10, 2014 at 8:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I understand your dilemma. If you recall, I suggested that most peeps seriously underestimate the dificulty of making 35s fit. I suspect that even Monte will admit that a little now. Plus, your balls to the wall :)D) approach does note help you here, in fact may put you in a bit of a predicament.
    FWIW, I have come to trust his judgement. Plus, he has now done it himself.
  13. Jan 10, 2014 at 8:39 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i am aware making them fit is a bitch and a half. but to what extent is what i dont really know! like if i trim as much as i can (which im prepared to do) and they still dont fit is what mont is concerned about. and how do i determine really if they dont fit!?
  14. Jan 10, 2014 at 8:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Don't forget, his main concern is the wide tires on the 10" wide rim. He's not telling you not to run 35s. Hes telling you that set may not be the right choice.
    I suspect that another set will come along that will be easy to tub for.
  15. Jan 10, 2014 at 8:46 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh of course. its that god dam extra 1.3" of width. i was so amped for a month for this, than the day before he leaves he has this revelation that it might not fit
  16. Jan 10, 2014 at 8:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I recall him saying something as soon as you disclosed they were 13.5s, not 12.5s and on 10" rims. And of course, back then he had not done it himself.
    Personal experience is everything in these situations man. :eek:
  17. Jan 10, 2014 at 9:25 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    I just got back from helping Monte tub Frank and I can tell you that his 12.5" are as big as you can go. his passenger rubs on the frame when its topped out and cranked all of the way. I'm with Mike on this one wait for a different set that's more appropriate for your application.
  18. Jan 10, 2014 at 9:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea...way harder then even I thought.
    Yea sorry man..it just worked out that I didn't get to it really and finished till yesterday.
  19. Jan 10, 2014 at 9:30 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    In before madjik makes a comment.:D
  20. Jan 10, 2014 at 9:34 PM
    BradyT88
