Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 18, 2014 at 6:44 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Here is mine. Black knob, shift it left handed. The cable is made for shifting a boat. I just leave the ADD in the locked position (like having the hubs locked in) all the time, although I did have a switch at some point. Laid flat against the tubing is 2HI, 4HI pictured, and 4LO is one click to the front. Works every time.
    Here is how it's hooked up to the shift shaft. There is a collar that goes over the shaft with a set screw, the collar is threaded and the cable screws into the collar. The tower supports the cable. It works well, but it is ugly.
  2. Feb 18, 2014 at 6:49 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    ill sell you an FJ case and the sticks for 500 + shipping :p
  3. Feb 18, 2014 at 7:01 PM
    BradyT88
    BradyT88 Well-Known Member
    Maybe if you still have it in a few years. haha
  4. Feb 18, 2014 at 7:36 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    The drivers side wheel pulls when i brake, i can actually see it. So i crawled under the truck and pulled off the drivers side steering boot. I grabbed the drivers side ram and was able to move it up and down. Not good... So i ordered up one from the wrecker, just waiting to hear the amount of kms.
    Im guessing it failed do to high kms and sloppy tierods. Also offoading doesnt help either
  5. Feb 18, 2014 at 7:43 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Bigger tires doesn't help that's why I have a complete (from outer tie rod to outer tie rod) rack and pinion as a spare, that I will no longer need in 4 month:D
    and as far as all this Tcase business goes I still say Atlas= cheap aint bad ass and bad ass aint cheap
  6. Feb 18, 2014 at 8:31 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    The driveline started making another new noise! Not much left to not make noise so my guess is pinion seal again or u joint for real. Wish I had more time to fix this shit
  7. Feb 18, 2014 at 9:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Its probably a u-joint if its making a noise. Have you greased them lately?
    I don't think pinion seals make a noise... They just leak. Ask me how I kno. :(
  8. Feb 18, 2014 at 9:19 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    pinion bearing might make noise
    Otherwise its the carrier(steady) bearing or ujoints
  9. Feb 18, 2014 at 9:24 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    hmmm, i thought mine made noise the last time. maybe it was something else making the noise
    and i just recently got my oil changed and they were supposed to grease them, i can do it again but im going to assume its been done. might just be time for new ones
    oh thats encouraging lol! its under acceleration. actually all of my rear end noises are under acceleration/power. some only in a specific range of speed lol
  10. Feb 18, 2014 at 9:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    wait....:confused:
    you have no power so how do you have noises then?
  11. Feb 19, 2014 at 7:00 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    AHHHHHHH!!!!! :laugh:
    that was good
  12. Feb 19, 2014 at 7:11 AM
    rctoy
    konstantenos
    Pocatello Idaho
    we should service your diff.. and by that i mean pull out the diff and make sure that non of your used bearings are going out.
  13. Feb 19, 2014 at 7:54 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Lol...
  14. Feb 19, 2014 at 8:05 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Mark, we are good to go on rusty nail and cliffhanger
  15. Feb 19, 2014 at 8:59 AM
    scocar
    scocar Patron of the Farts
    There are two things wrong here.
  16. Feb 19, 2014 at 12:39 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    That is a very good idea. I had planned on doing it, I just have to find a time I can have the truck down long enough to do that
    Fuck yea!!
    Haha I like the shop and trust em for now
  17. Feb 19, 2014 at 1:31 PM
    rctoy
    konstantenos
    Pocatello Idaho
    oh mark this was $900 to my door step. How much has your elocker cost you??
  18. Feb 19, 2014 at 2:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ok if i knew i could get the arb for 900 i probably would have ordered it. i was expecting it to run 1200 plus air compressor. the axle job was 700
    I replaced that inner axle seal again today. put some grease on the race to check the depth and the seal sits basicially in the middle of the sealing surface, so that should be good. cleaned off the wheel like you said, i guess ill see what happens.
    also doing the dif breather mod while im down there
  19. Feb 19, 2014 at 3:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ARBs have been 900 for like...years dude...down to 850 on sales...haha...
  20. Feb 19, 2014 at 3:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    850
    wut
