Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 7, 2012 at 11:48 PM
    #5041
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How about at my shop? could fit almost everyone in it..:D
  2. Mar 7, 2012 at 11:52 PM
    #5042
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    my ride is stiff but smooth it's weird i don't know how to explain it other than that. I should be able to fit 33's with no rub
  3. Mar 7, 2012 at 11:54 PM
    #5043
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    Yeah loving OME. The Eibachs weren't bad (rode great IMO @ 0.85") I just didn't want a pre-loaded coil along with my bumper. Also the Eibachs just didn't have enough strength to handle the weight. Turning and response felt sluggish but once I went to the 886x complete difference.
    I cut a lot to fit my tires however I am getting random rubbing on my cab mounts now. I already have my BAMF plates to weld on so I just gotta find time to take her under the knife...... and then find someone who can weld.....
  4. Mar 7, 2012 at 11:56 PM
    #5044
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think its funny that OME coils lift better the Eibachs on 2nd gens ha Total opposite for 1st gens.
  5. Mar 7, 2012 at 11:59 PM
    #5045
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    hit up travis I need a grinder to cut my cab mounts he's going to weld them on for me
  6. Mar 7, 2012 at 11:59 PM
    #5046
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Yeah I did the carrier drop and really no vibes ever. Driven straight ever since both installs of 5100/OME.
  7. Mar 8, 2012 at 12:00 AM
    #5047
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I don't have a carrier bearing. my front diff has vibs but ECGS has a fix for that now.
  8. Mar 8, 2012 at 12:27 AM
    #5048
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    my camburg UCAs are perfectly within spec that might change with the larger tires but damn the ride is so much better than stock ball joints
  9. Mar 8, 2012 at 6:53 AM
    #5049
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    They have had that for years, ARB air locker...you might as well stuff one in there while you have it apart. The bearing fix is just as time consuming.
  10. Mar 8, 2012 at 9:27 AM
    #5050
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  11. Mar 8, 2012 at 9:31 AM
    #5051
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Me too. woot...
  12. Mar 8, 2012 at 9:33 AM
    #5052
    MTgirl
    Weesa
    Bob's secret mod lair
    Welcome to my world. 9+ hours a day lately....breakfast and lunch at me desk...and it isn't even the busy season yet!
  13. Mar 8, 2012 at 9:39 AM
    #5053
    MTgirl
    Weesa
    :smack: I wouldn't do that. What if the teacher asks to see the drawing file? They can see that you forced dimensioned.
    its a bad habit to get into. I see it everyday and its frustrating.
  14. Mar 8, 2012 at 9:42 AM
    #5054
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I get to answer phones all day and send quotes via email
  15. Mar 8, 2012 at 9:52 AM
    #5055
    MTgirl
    Weesa
    If the measurements are close but not spot on it may be an issue with the tolerances of the dimensions - you can adjust how it rounds off numbers.
    If I was the teacher and saw that there was forced dimensions on a project I would give you a failing grade. Even if everything else was done correctly. Just sayin' :cool:
  16. Mar 8, 2012 at 10:01 AM
    #5056
    MTgirl
    Weesa
    Sounds like someone needs a timeout from TW.....
  17. Mar 8, 2012 at 10:11 AM
    #5057
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I hate these tempature swings it's hell on my neck and back
  18. Mar 8, 2012 at 10:16 AM
    #5058
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It's like mid 40s
  19. Mar 8, 2012 at 10:26 AM
    #5059
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Time for board shorts
  20. Mar 8, 2012 at 10:28 AM
    #5060
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Time to get my burn on
