Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 31, 2014 at 12:57 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The more I think about this the more I believe that the higher octane is masking the issue. You do not have a superchargcr :)D), so you have not increased the pressure in the combustion chamber to require a higher octane.
    In your trip out here it was not consistent because the formulation of the fuel here is not the same as what you get in CDA/Moscow.
    I also think being a sea level uncovered the flaw in your solution. 89 was not enough to mask the issue. At sea level you would of had to run 91 or 93 to mask it in the same way.
    I also go back to the fact that your random plug has varied corrosion on its surfaces depending on which side is facing the injector. Run your seafoam in the fuel to see if it is varnish in the fuel system creating the trouble.
  2. Mar 31, 2014 at 1:21 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    carbon buildup wouldn't get burned off if it's at the point where it has a deposit on the cylinder walls. kinda like carbon buildup on gun internals
    I know jack shit about engines but chem's my thing. hope the seafoam works
  3. Mar 31, 2014 at 1:27 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea but if a knock sensor is bad..it'll throw a code or put the truck in limp mode. Which is what happens when you have knock..so its not failing but something is happening that is making a code not be thrown.
    was a popular thing for supras to rewire them directly with heavier shielded wire as they would pick up interference in the harness and up the car in limp mode.
  4. Mar 31, 2014 at 6:00 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Did you scan forcodes anyways? Ur little light might be out :notsure: i say go borrow a scanner from ur auto store and see if anything comes up, unless you already did :eek:
  5. Mar 31, 2014 at 7:02 AM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Elevation and humidity will affect the way fuel burns. There is more oxygen at sea level than in Moscow and correlate. That could also be a factor in pre ignition that would explain the problems at sea level. It also could be timing chain stretch:stirthepot:
  6. Mar 31, 2014 at 7:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh yea..could be a timing issue..
    you've had your timing belt replaced right ben?
  7. Mar 31, 2014 at 7:08 AM
    SconnieHailer
    Marc
    Actually, it sounds like you should go spend a while at Monte's place while he does a 2jz swap for you :p
  8. Mar 31, 2014 at 7:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hell no!
    im going to do that first :D haha
    then he can come :p
  9. Mar 31, 2014 at 8:11 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    this is the first and only thing ive read but typically in the case of an octane solved issue either youre pushing lots of boost on stock internals and need to either lower your boost or lower your compression OR you need to clean the carbon out of your motor via some sort of high end cleaner and rod the piss out of the truck while you do that.
  10. Mar 31, 2014 at 6:15 PM
    BradyT88
    BradyT88 Well-Known Member
    The root of your 2 year knock maybe?
  11. Mar 31, 2014 at 10:27 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    multiple orgasms were had
  12. Mar 31, 2014 at 10:31 PM
    Slodgetto
    Slodgetto Ăśber Posre
    Silas
  13. Mar 31, 2014 at 10:33 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    get out, you never post in here. you cant just show up randomly for one picture then leave again :p
  14. Mar 31, 2014 at 10:34 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    That's exactly what I am going to do. Link to a build...or more pics?
  15. Mar 31, 2014 at 10:35 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    haha.
    i got it from the solid axle thread
    guy only has 30 posts, so i doubt there is one here. maybe pirate?
  16. Apr 1, 2014 at 6:58 AM
    rctoy
    konstantenos
    Pocatello Idaho
    yeah im kinda going for the same thing only mine will be taller.
  17. Apr 1, 2014 at 10:00 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Low and wide = way better
  18. Apr 1, 2014 at 10:02 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Until you hit a bump going 30mph haha
    Just depends on how you want to use it.
  19. Apr 1, 2014 at 10:24 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I just think if your going sas, you would want to stay low and maintain as much droop as possible. Uptravel isnt really necessary. A good shock or coil setup will handle bumps just fine... Dont need to be jacked up 4' in the air to handle bumps. Also sas inst meant for hauling ass over bumps
  20. Apr 1, 2014 at 10:26 AM
    PcBuilder14
    Brent
    Nor Cal
    Like I said, it is dependent on how you plan to use it. Your statement makes sense if it's strictly a rock crawler.
