Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 20, 2014 at 11:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Get an alignment dude. The tech will be able to tell you immediately of you have worn front suspension components and be able to identify them for you.
    BTW, I'm pretty sure the camber being out can cause all that odd wear you are seeing.
  2. Apr 20, 2014 at 11:03 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea i'll bet its just alignment.
  3. Apr 20, 2014 at 11:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have to go get one this week. My front wheels look like Igor's eyeballs after doing the LBJs and TREs. :p
  4. Apr 20, 2014 at 11:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I swear...once the LT goes on...getting an alignment..then welding the bitch. problem solved..haha
  5. Apr 20, 2014 at 11:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea they do help a lot.
    and i don't mean burn em in completely. You just tac them. Then you can grind it off and re align it if you really have too.
  6. Apr 21, 2014 at 12:00 AM
    tacoleap88
    tacoleap88 Well-Known Member
    Anyone here in/near Lewiston/Clarkston?
  7. Apr 21, 2014 at 12:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea right..your just starting your build..haha not even in its adolescence yet! haha
  8. Apr 21, 2014 at 6:40 AM
    BradyT88
    BradyT88 Well-Known Member
    m3bassman is in CDA/Moscow.
  9. Apr 21, 2014 at 7:07 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Lol
  10. Apr 21, 2014 at 7:22 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    even when it's built it's still not built.
  11. Apr 21, 2014 at 7:49 AM
    BradyT88
    Cameron got his new tires and added his 5100's for a new lift and only put 300 miles on his rig and it ate the edges off his tires pretty badly... Got an alignment and it stopped eating the edges. Uneven tire wear is mostly all alignment. IFS by nature will round off the edges of your tires because as the suspension cycles it changes the camber and that is why rotating them is important, but a bad alignment will eat tires very quickly.
  12. Apr 21, 2014 at 8:18 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    That reminds me...I need to get an alignment and rotation again soon. I just hope I don't have to argue with discount again. :facepalm:
  13. Apr 21, 2014 at 8:22 AM
    BradyT88
    Cupping is caused by bad toe most of the time, but as you point out, my KM2's have also cupped, but my alignment is all sorts of fucked up most of the time so I just expect it.
  14. Apr 21, 2014 at 9:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    For all you know, that just lost a bit more on a rock.
    Just go get an alignment already. They will be able to tell you.
  15. Apr 21, 2014 at 9:57 AM
    rctoy
    konstantenos
    Pocatello Idaho
    maybe you need to rebuild the entire truck.
  16. Apr 21, 2014 at 10:57 AM
    Rob720
    Rob720 Well-Known Member
    Robert
    Boise, ID
    12' DCSB Super White
    OME 885's with Dakar leafs, Nitrocharger shocks, Pelfreybuilt HC rear bumper, swing gate tire carrier and rotopax, OBHS
    Have a set of TRD OR wheels off my 12 for sale if anyone on here wants them I'll let them go very cheap. Same for a rear bumper with tow package.
  17. Apr 21, 2014 at 11:04 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    New wheels!?
  18. Apr 21, 2014 at 7:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Apr 21, 2014 at 7:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hopefully man. Jealous you'll be done. THis should be my last semester technically..
    That photo class is gonna suck haha
  20. Apr 21, 2014 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    really! haha!
    Dude i am taking astronomy next fall! LOL
    and yes, I have enough creidets ill be a super seinor next fall. But none that count to graduate. I have a shit load of credit hours. Hell i had like 136 from my last school..
