Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 1, 2014 at 9:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Never be a bolt in option. Already in jeep Cherokee I think..
    Not sure I'd want it. More electronics..
  2. May 1, 2014 at 9:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm not totally familiar with exactly how they function. But all the wiring need to drive the electromagnets and such would put off a lot of people I feel like. Just me.
    Aren't they bigger then normal shocks too?
  3. May 1, 2014 at 9:40 PM
    rocktoy
    rocktoy Well that escalated quickly! But it was fun.
    Rocky
    poky
    sased 2nd gen 3.4runner
    sas, 4.88, 3.4swap, rear spool, front arb, cheap led light bars, tg front bumper, self built slider and rear bumper, pg octane r 12 subs, vision x rock pods
    :rofl:wait. the light god himself doesn't want more electronics?
  4. May 1, 2014 at 9:41 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I would think that wiring wouldn't be any more complicated than a central hub with 4 wiring harnesses to go to each shock :notsure:
  5. May 1, 2014 at 9:45 PM
    rocktoy
    Rocky
    poky
    you could likely pair it up front pair and rear pair on two potentiometers and bamo you have a controlled voltage to electro magnet.
  6. May 1, 2014 at 9:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ride dependent electronics I suppose.
    Ah gotcha.
    Well. Idk. Could be interesting.
  7. May 1, 2014 at 10:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I tought I'd share this with you guys. The definition of well loved. Has the epic written all over it.
  8. May 1, 2014 at 10:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    hell ya!
    Im dying to see my skids close up. haha
  9. May 1, 2014 at 10:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I've been on a mission since its been so nice here for the last few days. High of 84* today. :eek:
    Working through all the surface rust on the skids and sliders. Using a wire wheel in a 4" grinder. Clean everything up and repaint so she looks purty again.
  10. May 1, 2014 at 10:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    been chilly here. was 70-80 for like 2 weeks. and then...bam..50 haha was odd.
    in a week though WYOMING!! :goingcrazy: then ill be painting stuff :D my sliders are MAJORLY over due haha probably skids too..and frank needs a bath super bad. And interior put back together from tub job.
  11. May 1, 2014 at 10:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What day do you figure on getting home?
    Hell Yeah, get to work on your truck again.
  12. May 1, 2014 at 10:35 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    got me thinking. instead of bolting that sucker to the axle, what about just welding a skid plate to the bottom of it? Might sit up a hair higher too.
    also, might have found myself a nice gal :eek:
    She agreed to come wheeling with my next weekend...
    and actually loves out doors shit
    And is rather cute
  13. May 1, 2014 at 10:39 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Does she look like this? :p
  14. May 1, 2014 at 10:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    They do make them that way too (not BAMF) but then you'd have to have a hole in them for the drain plugs.
    You are correct tho, The one does reduce ground clearance just a bit. Probably why there are so many marks on it. :laugh:
  15. May 1, 2014 at 10:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    May 11th i should be home that evening. Get a week till i have to start my summer job to hang with my dad and work on trucks! Got a shit load to do.
    Blue Torch Fab makes a weld on diff cover. Its for the rear half. THe toyota housing on the bottom is pretty damn stout as it is. its the rear section that is super weak. I dented mine in two places. the BAMF one helps cover the full diff though. Is pretty damn handy to have and not worry about the diff at all.
  16. May 1, 2014 at 10:49 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    straight off her fb page
    bleh, ill make my own. shape some pieces of metal and weld them together at angles to make a bowl shape then attach to axle. done:D
  17. May 1, 2014 at 10:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Her name is Manuela
  18. May 2, 2014 at 12:10 AM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Dude I'm with you. This would be totally cool and workable from a wiring aspect. +1
  19. May 2, 2014 at 12:11 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    ben you make those shocks and ill synthesize healthy bacon
    we'll rule the world
  20. May 2, 2014 at 12:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lets steal the ones in grandpas camaro and fit em to yours :laugh:
