Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 7, 2014 at 9:00 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It's not shit, it's just not as precise. The weld itself is wider, but just as strong as TIG. In many applications, MIG is much stronger. Notice how clean every joint is on the Camburg build? You don't have to do that with MIG, especially flux core. You can burn right through the scale and pickling to produce a strong joint. That is not the case with TIG. In addition, did you notice the tack welds on those tubes? MIG. You can do it with one hand. I'm not trying to dis TIG, I'd love to have one, but even at my income bracket it isn't a reasonable purchase, and I make a metric fuckton of money.
  2. May 7, 2014 at 9:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Okay. I'm down. Sme nice studios in Seattle.
    Why I like using hand tools to make stuff. Just get lost in perfecting the one thing at the time. Super fun. Glad my dad is such a hand tools guy.
  3. May 7, 2014 at 9:10 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Ok.
    Step one- Join the Military in a technical field
    Step two- Apply the skills you learn and get a real job
    Step three- Marry a stripper and lose it all
    Step four- Re-enlist cause you're homeless
    There are some more steps in there somewhere.
    :D
  4. May 7, 2014 at 9:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  5. May 7, 2014 at 9:11 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    You guys and your welding talk of mig this and TIG that. Tig is a our weld and can't get slag inclusions. Mig is easier and for most off-roading applications it is all you need. If you welding aluminum or stainless then TIG is the way to go. If you want the penetration them go with FCAW or stick. It all has a place.
    I am only going to school for this shit but then again I wouldn't know anything. Seen 1/16" FCAW burn straight through a 3/8" plate, needless to say that was cool
  6. May 7, 2014 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your out of school a lot sooner then I am..problem one..haha
  7. May 7, 2014 at 9:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Valid point..
    You design it. Ill weld it.
    Be cool no doubt.
  8. May 7, 2014 at 9:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay haha
    And yea..:eek: always sucks no doubt..
  9. May 7, 2014 at 9:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The ol' Catch 22
  10. May 7, 2014 at 10:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Just because
  11. May 7, 2014 at 10:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. May 7, 2014 at 11:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No thanks..
  13. May 7, 2014 at 11:23 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Thank you. that is exactly what I was saying, just not as detailed
  14. May 7, 2014 at 11:28 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    its a tough fucking game getting your foot in the door, then again when you are trying to move up. What makes you so special? How are you going to market and sell yourself when you get graced with the opportunity to interview.
    Look in the right spots for jobs. Above all else, fuck find a mentor in the field to give you advice and coach you and help you get out to meet potential employers and net work NOW! Not when you are a month from graduation. Not necessarily looking for a job...try to get people to remember you.
    Think to yourself, if you only had 2 minutes in an elevator with the employer that could launch your career what would you say to him? How would you introduce yourself? How would you ensure that when you go for an interview down the road that he remembers you?
  15. May 8, 2014 at 5:47 AM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    Same damn thing in my field, every machine shop wanted 5years at least on CNC. I finally stopped calling the front desk and HR at the one place I wanted and called a machinist there and the next day he said he had his supervisor find my resume out of the stack on his desk and give me a look so he did and well I start on the 19th... Its all about getting behind HR and the front desk
  16. May 8, 2014 at 6:38 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    I've always thought it'd be a blast to build one of these. Cheaper than building a full blown race car yet you could probably smoke anything with 4 wheels with the right setup lol. Just don't flip it! :D
  17. May 8, 2014 at 10:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben, that badlands bumper..is in MT..you are just stuborn to pass up on it. Half off. Pick it up later in the summer.
  18. May 8, 2014 at 5:44 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Just finished watching that build! Haha
  19. May 8, 2014 at 5:57 PM
    BradyT88
    BradyT88 Well-Known Member
    Any particular reason to do a jeep rather than say a 1st gen or older pickup?
  20. May 8, 2014 at 6:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Look who wants to build a rock crawler now lol
