Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 2, 2014 at 9:40 AM
    BradyT88
    BradyT88 Well-Known Member
    The lines wouldn't have 2000, but maybe like 900. haha You are already carrying an 800 psi bottle on your rig. I doubt you would notice a difference between 800 psi and 2000 psi should the bottle rupture. If properly mounted it shouldn't be an issue though.
    True. haha I was just kind of pointing out a difference between street and offroad. The other downside is that if you are going by vibrations, pitch, yaw, etc, you are trying to react to things that basically already happened, which again kind of makes it a luxury thing. You hit a pot hole and the suspension tries to smooth it out after. If you hit whoops at a 100 mph, you want the suspension to already be set before you hit said whoops. This is why I said a system would be ungodly expensive as it tries to map out the terrain ahead of you.
  2. May 2, 2014 at 9:43 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    interesting discussion in here!
  3. May 2, 2014 at 9:43 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    it wouldn't map it out infront, it would happen at the moment of impact..or within milliseconds or micro seconds..depending on several factors..
    CO2 is stored as a liquid, if it bottle ruptures it won't become a missile...unlike the nitrogen..
  4. May 2, 2014 at 9:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just ya know..starting Bens career off with the next gen offroad suspension...apparently..haha
  5. May 2, 2014 at 9:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Computer yes, but a computer that'll go in car? idk. thats where one of the biggest compromises will be. While mobles have quad core now so might not be an issue. I havn't been following much lately for that stuff..
    have to wait to get home to watch that..no youtube in the lab im in.
  6. May 2, 2014 at 9:46 AM
    SconnieHailer
    Marc
    sweet vid ben
  7. May 2, 2014 at 9:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    we all want credit in helping inspire you..haha
  8. May 2, 2014 at 9:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty sure you stole it from the guys that put it in cars first...haha
    so..probably some german..
  9. May 2, 2014 at 9:52 AM
    BradyT88
    That's what I was saying. In order to have a feasible system for racing it would have to have a prediction system. For daily drivers a moment of impact system could work though.
    If the bottle is properly strapped down it shouldn't go anywhere though.
    Embedded systems are your friend here! Embedded systems are dedicating a processor to basically a single function so it would take multiple embedded systems, but they are relatively cheap to design and respond very rapidly since they only have 1 or 2 things to worry about. They could then communicate to a larger system capable of handling all the traffic of the smaller systems.
    I'm sure it can be done. Most anything can be done if you have enough money and limited constraints. Google has built cars that can literally drive themselves around town, know how to react to stop signs and other cars and everything. They have logged over 600,000 miles in these cars with no issues. But the systems to do this are huge and expensive. They take up the entire trunk space of the vehicle. So it can be done, but it's just no where near feasible yet and may never be.
  10. May 2, 2014 at 9:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    right..sure..haha
    thats the american way!
    actually isn't it the Chinese?
  11. May 2, 2014 at 9:55 AM
    BradyT88
    No the Chinese just straight up steal things. haha
  12. May 2, 2014 at 11:06 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I will be the dissenting voice here. My truck rides as well as a factory Tacoma on the street. The spring rate is more stiff so it doesn't wallow around in the corners (body roll) as bad as a stock one, but the valving absorbs small imperfections in the road, like potholes and expansion joints as well as a factory truck. You guys should ride in one that's valved right. I took one ride in a full LT truck and started buying parts that month. I have a progressive valving rate due to the shock design as well as bypass set up. It's soft at ride height, and ramps up to massive resistance in the bump zones. I also think "smart" shocks will eventually catch up to the offroad performance of kings/fox/icon, but it will be many years from now. Street tuning is easy. Offroad shock tuning is more of a black art, and really tuned more to the driver than the car.
    EDIT: also it is moot point not mute point.
    moot
    mo͞ot/
    adjective
    adjective: moot
    1. 1.
      subject to debate, dispute, or uncertainty, and typically not admitting of a final decision.
      "whether the temperature rise was mainly due to the greenhouse effect was a moot point"
      synonyms:debatable, open to discussion/question, arguable, questionable, at issue, open to doubt, disputable, controversial, contentious, disputed, unresolved, unsettled, up in the air More"a moot point"
      • North American
        having no practical significance, typically because the subject is too uncertain to allow a decision.
        "it is moot whether this phrase should be treated as metaphor or not"
    verb
    verb: moot; 3rd person present: moots; past tense: mooted; past participle: mooted; gerund or present participle: mooting
    1. 1.
      raise (a question or topic) for discussion; suggest (an idea or possibility).
      "Sylvia needed a vacation, and a trip to Ireland had been mooted"
      synonyms:raise, bring up, broach, mention, put forward, introduce, advance, propose, suggest More"the idea was first mooted in the 1930s"
    noun
    noun: moot; plural noun: moots
    1. 1.
      British
      an assembly held for debate, especially in Anglo-Saxon and medieval times.
      • a regular gathering of people having a common interest.
    2. 2.
      Law
      a mock trial set up to examine a hypothetical case as an academic exercise.
    Origin
    Old English mōt ‘assembly or meeting’ and mōtian ‘to converse,’ of Germanic origin; related to meet1. The adjective (originally an attributive noun use: see moot court) dates from the mid 16th century; the current verb sense dates from the mid 17th cent.
  13. May 2, 2014 at 11:53 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Nope, they built it into their RS9000 shocks.
    I don't think it worked very well though because there isn't anybody carrying the controller, and the shocks now have a manual tuning valve thingymabob.
    http://www.gorancho.com/shocks.php?shock=RS9000XL
  14. May 2, 2014 at 12:01 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  15. May 2, 2014 at 12:35 PM
    BradyT88
    I see. I seem to recall you saying at one point, that people who ride with you are surprised at how rough it rides on road, but are then stunned at how smooth it is offroad.
    Also I have never road in a bone stock 2nd gen so I don't know what it rides like. My rear may actually be smoother than I think it is. I am basically comparing it to my front. My front is way smoother than my rear. I can hit huge speed bumps and my front end just smoothly glides across them and my rear is somewhat jarring (at least compared to the front that you don't even feel it). When I get off road my front end can't keep up with the rear though. I can't really compare my new setup to my old per se, because I didn't exactly hit specific speed bumps with old setup in a manner of "collecting data" for comparison. I do know the new bucks less than the old and I can go faster through whoops. haha It doesn't help that the old setup there were about 4 months between removing the old setup and completing the new one, which I have yet to even take it out completed.
  16. May 2, 2014 at 12:43 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I've fixed a lot of stuff since then... Mostly turned the tubes wide open at ride height, new tires at a lower psi, and insulated the shocks better with poly bushings. One of my kings is leaking, time for a rebuild and I might play with the valving even more (softer compression) as I can't bottom it out as it is. Well, I could, but it would require some likker. :D
  17. May 2, 2014 at 12:45 PM
    BradyT88
    Got ya. Well I still have a ways to go. haha
  18. May 2, 2014 at 11:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  19. May 2, 2014 at 11:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    He sure gets around haha
  20. May 2, 2014 at 11:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    #noschoolrestrictions :rolleyes:
