Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 13, 2014 at 7:30 PM
    rocktoy
    rocktoy Well that escalated quickly! But it was fun.
    Rocky
    poky
    sased 2nd gen 3.4runner
    sas, 4.88, 3.4swap, rear spool, front arb, cheap led light bars, tg front bumper, self built slider and rear bumper, pg octane r 12 subs, vision x rock pods
  2. May 13, 2014 at 8:01 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Yup. And right now I'm tryin to play without paying and it's going to catch up with me
    Hell ya! I'm gonna go wheeling come hell or high water!
  3. May 13, 2014 at 8:44 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Maintenance and spare parts come to about 260 with an discount. Sweet. Much needed though.
    And Ben, I've seen that atrocious mess driving around. It makes you want to gouge your eyes out
  4. May 13, 2014 at 8:46 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  5. May 13, 2014 at 8:55 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Mark...youll be fine lol
  6. May 13, 2014 at 9:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  7. May 13, 2014 at 9:12 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I'm not sure if y'all realize how much I DON'T trust that e locking rear lol.
    But Lauren if you couldn't hold me and comfort me and tell me everything will be all right maybe I can make it through it.
  8. May 13, 2014 at 10:47 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    dude if it comes down to it, not only will i stay locked the whole trail...Ill just take the motor off, slide the rack all the way to locked and be locked the entire week.
    making turns in town will suck ass though
  9. May 13, 2014 at 10:50 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    What's up with your e-locker anyways?
  10. May 13, 2014 at 10:55 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i fried a coil in the motor so it works kinda when it feels like,
    im pretty sure i know when it happened too. It was over spring break, and i was with brady on a trail run. had the locker in, went up a waterfall, got to the top the locker unlocked and wouldnt lock again. i assumed the worst, turned out it was only a fuse that blew. so i replaced the fuse and that was when it started to work, kinda when it felt like. so a couple weeks ago andy and i completed disassembled the motor and thats when we found a burnt up coil.
    and the thing that i think caused it, is since my tub job my locker relay was just kind of tucked up behind the kick panel all whatever like. and the metal plugs going to the relay were exposed (i have since covered the whole thing in tape) and i bet on the obstacle the relay moved and hit something and shorted out, and while it blew the fuse, it also shorted out something back at the motor too.
  11. May 13, 2014 at 10:57 PM
    PcBuilder14
    Brent
    Nor Cal
    Dang... Hated dealing with my e-locker issues.
    Sounds like you just need to give and and get this then haha
    http://www.lowrangeoffroad.com/inde...-toyota-electric-locker-cable-conversion.html
  12. May 13, 2014 at 10:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  13. May 13, 2014 at 11:01 PM
    PcBuilder14
    Brent
    Nor Cal
    Surely not dual ARB's....
    One, probably haha
  14. May 13, 2014 at 11:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No think he has like 8-900 in that damn axle haha
    So not quite duals. But definitely a rear.
  15. May 13, 2014 at 11:04 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I looked into that...and 600 freaking bucks for some cable and a pully? Thats crazy. You have to destroy the old locker motor as well to get it to work. Screw that. And thats what i thought too monte! Could pay the full price for an arb and compressor if i threw that sucker on there. ill just find a used motor for half that.
  16. May 13, 2014 at 11:05 PM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, still not quite enough for just the locker haha close though.
    But then he still needs a compressor...
    Good luck finding a locker motor under $500-$600....
  17. May 13, 2014 at 11:06 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    if you add the pully thing to what ive already spent i would be at a rear with compressor and switches and some other shit.
    or almost 2 arbs:eek:
  18. May 13, 2014 at 11:06 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    believe me, its easier than finding an entire third or the correct axle housing within a reasonable distance.
    at least you can ship a motor
  19. May 13, 2014 at 11:07 PM
    PcBuilder14
    Brent
    Nor Cal
    Y'all's numbers are confusing me.... Over $2,000 just for the lockers front and rear.
  20. May 13, 2014 at 11:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you can get arbs for under a 1000 padawan ;)
