Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 23, 2014 at 8:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sweet man
  2. May 23, 2014 at 8:37 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    'Cause you have to, you know, work. That shit sucks, no matter the field you are in. We can't all be Hugh Hefner.
  3. May 23, 2014 at 9:27 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Have you thought about being a wild land firefighter? I did it for a couple of summers, made some loot, and got to work in the woods. Plus, you can't spend the money you make so you come home with a nice bankroll. I built my first race car that way.
  4. May 23, 2014 at 10:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben would die haha
    Also he has school
  5. May 23, 2014 at 10:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ben, what's your job at the restaurant?
  6. May 23, 2014 at 10:44 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    :spy: what's that stench here in cda?
  7. May 24, 2014 at 9:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Gotta love (almost) summer solstice. Its 9:30 here and still light outside. :woot:
  8. May 24, 2014 at 9:39 PM
    skygear
    skygear                    
    Huh, Mcdonalds? Nice. Some countrys there are hours worth of waiting lines for service..
  9. May 24, 2014 at 9:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wut?? :confused:
  10. May 24, 2014 at 10:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you leave pissed tonight?
  11. May 24, 2014 at 10:53 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    That's how you end up with child support payments.
  12. May 24, 2014 at 11:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You mean, not between fins but at the narrow end. It tore near the section next to the clamp!?
  13. May 24, 2014 at 11:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup
    :wave: Hi Zach, I see you. How are things with you?
  14. May 24, 2014 at 11:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I suspect that the true boot slide mod would not cause those problems. But then, the true mod is much less easy to do so most that did it, like you, took certain shortcuts...
    Which end up biting you in the ass.
  15. May 24, 2014 at 11:36 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    hi dur
  16. May 24, 2014 at 11:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The one thrown around here is the lazy way. Doomed for failure from the beginning. :rolleyes:
  17. May 24, 2014 at 11:56 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  18. May 24, 2014 at 11:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    since repairing the boots...no issues thus far.
    luck?
    further evidence that 95-97 take lifts better?
  19. May 24, 2014 at 11:58 PM
    PcBuilder14
    Brent
    Nor Cal
    What many people do is remove the original clamps, stretch the boots and put clamps back on.
  20. May 24, 2014 at 11:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There are three difference from what most, like Ben, did.
    The correct sized (width) clamp, a new CV boot and a tab welded to the shaft that does the real work of not allowing the boot to slide back.
    Without the inner tab, the clamp has to really be on very tight. So tight it eventually damages the 10, 11, 12, 13 or 14 year old rubber stock boots. Causing them to tear.
