Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 4, 2014 at 7:33 PM
    BradyT88
    BradyT88 Well-Known Member
    That's true. On the way home my bed was basically empty but I couldn't really use my rearview mirror. haha
  2. Jun 4, 2014 at 9:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What was the shutter speed on this one? Do you recall?
  3. Jun 4, 2014 at 9:14 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I can fit enough camping shit for a week by myself on my motorcycle (pro tip: whiskey takes up far less room than beer). When the wife comes along, I use a 28' travel trailer and a crew cab chevy and don't have enough room. On the other hand, I can't make margaritas or microwave a hotpocket on the bike...
    That's some clean millin' up there^
  4. Jun 4, 2014 at 9:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    1/200|f4|iso400
  5. Jun 4, 2014 at 9:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Huh, I would have guessed much higher. The drill speed must not be as high as I thought it would be.
  6. Jun 4, 2014 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mills go mush slower then you'd think. Less friction is created so blades/bits last longer
  7. Jun 4, 2014 at 9:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have to say that the spectacularity :)D) of that photgraph has diminished greatly now that I know that mills are slow and the shutter speed was so low.
    The photo was way more interesting when I was ignorant. :rolleyes:
  8. Jun 4, 2014 at 9:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, quite nice Ben. I like the light. No flash sync required.
    Nice capture.
  9. Jun 4, 2014 at 9:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :yes:
    Going to my brothers after work tomorrow to see how much crap needs to be hauled to Mazama.
  10. Jun 4, 2014 at 10:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I haven't seen it but I'm told that one item is a wooden table that is oval in shape. I do not know its dimensions yet. Tomorrow.
  11. Jun 5, 2014 at 12:25 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ya know, I've been looking more and more and that seems like. Great compromise when I upgrade bikes. I want a street bike but I want to be able to ride off road too. And that seems like the perfect way to keep up with these goons for the overland trips when my rig becomes impractical for highway use
  12. Jun 5, 2014 at 7:05 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Read this for some motivation. This is the little brother to my bike, but if you aren't hauling passengers is just the ticket.
    http://advrider.com/forums/showthread.php?t=781893
  13. Jun 5, 2014 at 1:27 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    too many motherfuckers named cody up in here
  14. Jun 5, 2014 at 5:53 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    What's up fellas?!?!?
  15. Jun 5, 2014 at 7:24 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Yup. He was with the dude from inchworm gear. I talked to him for a little while at the dunes. Pretty darn cool guy!
  16. Jun 5, 2014 at 9:25 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    That was a pretty snazzy pop up he had
  17. Jun 5, 2014 at 9:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's a flipak. They are super cool but ya bit top heavy. Can't be much worse then a RTT though.
  18. Jun 5, 2014 at 9:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Are you sure its the same one? I was wondering that. Both trucks have a 5 ft bed but the width is quite different. :notsure:
  19. Jun 5, 2014 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I bet it's the same. He couldn't afford a new on I'm sure. Plus he got his for like 1200. I think for the flipak it's the same one for tacomas. I think..
    2nd gen bed sides dovetail that's why the rear corner pokes out a bit on his new truck
  20. Jun 5, 2014 at 9:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That thing has got to weigh in at way more than my rack/RTT combo
