Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 18, 2014 at 8:13 PM
    Cykososhull
    Cykososhull Better not bring your kids
    Anthony
    Texas
    03 Tacoma SR5 TRD
    uniden cb, Grey wire, Deck plate, OME 883 coils, Dakar w/D6XL, 4X innovations sliders, tinted windows, debadged, TG low profile bumper, Piaa lights, Allied soft 8s, Bighorn 285,75,16s
    I don't care for 6", but if its not worth the trouble of swapping back to 3", maybe leave it?
  2. Jun 18, 2014 at 8:13 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yup, drop bracket lifts require you to cut out the original crossmember...
    Sound like a lot of work, to get everything switched...
    I'd try to find a Tacoma without a 6" lift, but that's just me.
  3. Jun 18, 2014 at 8:21 PM
    BradyT88
    BradyT88 Well-Known Member
    Logan beat me to it. I was going to say the same thing about the frame getting fucked but the bumper fairing pretty well.
    I would pull the bracket off, gusset the shit out of it and put it back on. Konsta wheels the shit out of his rig with his 6" DB lift and does great. He outwheeled both Mark and I and kept up with Rocky and his 38.5's pretty well.
  4. Jun 18, 2014 at 8:24 PM
    PcBuilder14
    Brent
    Nor Cal
    True, get a good set of coilovers/uca's for the front and a full leaf pack for the rear and you'd be set.
  5. Jun 18, 2014 at 8:24 PM
    Cykososhull
    Anthony
    Texas
    03 Tacoma SR5 TRD
    Excuse my ignorance, but what is "gusseting." Wouldn't all that cutting and welding potentially harm the integrity of the frame?
  6. Jun 18, 2014 at 8:25 PM
    PcBuilder14
    Brent
    Nor Cal
    This is an example of a gusset.
  7. Jun 18, 2014 at 8:28 PM
    BradyT88
    welding extra metal onto things to reinforce the weak spots! :D
    Konsta was just rocking stock arms and SAW C/O's up front with 3" spacers and then an expo pack on lift blocks in the rear. Not sure what his rear shocks are.
  8. Jun 18, 2014 at 8:37 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Dang, at least I know my bumper holds up well. That sucks.
  9. Jun 18, 2014 at 8:38 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, now think if he had full leaf packs and coilovers haha
  10. Jun 18, 2014 at 8:47 PM
    BradyT88
    Well with a drop bracket he won't necessarily have any more flex up front than rig with a 3" lift and those SAW's are pretty good C/O's. He could definitely have more flex in the rear but he did out walk both Mark and I on the RTI ramp.
  11. Jun 18, 2014 at 8:48 PM
    PcBuilder14
    Brent
    Nor Cal
    Wouldn't he be able to achieve more up-travel? Or am I thinking about this all wrong?
  12. Jun 18, 2014 at 8:50 PM
    Cykososhull
    Anthony
    Texas
    03 Tacoma SR5 TRD
    Thanks for the info guys. I'll keep ya updated. Gonna look at that taco next weekend. Its a great deal for the condition and miles. He picked it up back in 04 on a repo. So you guys would recommend replacing the uca's and coils. The guy sounded older (like 55+) and probably wouldn't even know if it had aftermarket ucas already on it. Well at least I can sell my 4 mo old full OME kit and put that into upgrading the 6".
  13. Jun 18, 2014 at 8:56 PM
    BradyT88
    A drop bracket just moves the upper and lower farther apart, doesn't really change the arc path of the tire during flex. It's kind of the equivalent of a spindle lift for 4wd's. You gain lift and clearance via a "spacer" of sorts but travel is unaffected. The BJ's and CV's will still be your limiting factor.
  14. Jun 18, 2014 at 8:58 PM
    PcBuilder14
    Brent
    Nor Cal
    Ah, gotcha.
    That's why I was thinking aftermarket uca's with uniballs would be good for that. But then I guess the lca ball joint would be the limiting factor...
    Screw it, just through some lt control arms on there! Haha
  15. Jun 18, 2014 at 9:09 PM
    Cykososhull
    Anthony
    Texas
    03 Tacoma SR5 TRD
    Well if I end up selling my dakars with the OME aal, I'll hit you up Ben. :p
  16. Jun 18, 2014 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow. That looks like a really hard hit.
  17. Jun 18, 2014 at 10:14 PM
    BradyT88
    That is an understatement!
  18. Jun 19, 2014 at 6:55 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Be careful with that. If it has a branded title you will never be able to sell it (unless someone like you can pay cash, but no bank will touch it) and your insurance won't cover shit if you wreck it. Even if it's a repo or stolen, completely undamaged etc. People are also dishonest about why it may have a branded title. For all you know it could have been underwater in that hurricane back east, totaled and rebuilt, etc. See what carfax says...
  19. Jun 19, 2014 at 8:20 AM
    BradyT88
    I didn't know that repo'ing a rig would give it a branded title. Seems odd.
  20. Jun 19, 2014 at 8:50 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    this is true. Though i had mid travel in the front cuz of my coil overs giving me so much flex.
    Like i said below if you ran a track bar like i did you could get away with blocks but it's always better to have a full leaf.
    The rear set up was allpro 3" expos and 4" blocks under them with a track bar to keep from ruining a set of springs. Total i had 6" of lift cuz my truck is a fat ass and i only got 2" out of those expos. I had 12" shocks in the factoy posistion on the top and just welded shock tabs to the axle.
