Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 31, 2014 at 7:06 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    You sire are wrong. water will actually cool better than just strait coolant. it's conducts heat better. Where this theory of it not doing so well comes from is when you have pure water it boils at it's normal rate and freezes. That's why they have a mix of coolant to help stop that from happening while maintaining some of those better cooling abilities of water.
    That waterless coolant does work very well but it's not a normal eth-glycol coolant.
  2. Jul 31, 2014 at 7:08 AM
    rctoy
    konstantenos
    Pocatello Idaho
    there are so many other things at play besides just coolant. like timing and air fuel ratio (that's a big one). I would make sure those two things are perfect before you chase the cooling system anymore. I mean a weak water pump could cause that but it's a rarity.
  3. Jul 31, 2014 at 8:19 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That was my other thought, is that maybe the bike is working too hard at those higher speeds? But then I would think I would have different issues than just overheating.
    The cooling system is also the easiest to fix. I can pull the thermostat off the bike in about 20 minutes after I remove the extra crap around it.
    Dealing with timing and ripping Into the carbs is a lot more complicated haha
    Like he said, is it a problem to just take the valve out or whatever and have the coolant run through the whole system all the time? I don't know exactly how the cooling System works, but does it circulate in the engine then when it gets hot enough it opens and then runs through the rad? What not just have it flow through the whole system all the time?
  4. Jul 31, 2014 at 8:47 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I am no lord and carry no official title. I will agree to disagree. Water does absorb heat faster, but at temps of 250F, even under pressure it's boiling. It doesn't cool for shit when it's boiling. Also coolant transfers heat better, which is the whole point of a radiator. I digress.
  5. Jul 31, 2014 at 9:22 AM
    rctoy
    konstantenos
    Pocatello Idaho
    tis true water will boil at 250F but at lower temps water transfers heat better. If I was wrong why coolant and auto manufactures run anything but strait coolant and smaller radiators?? they are in the game to save weight and cram things into smaller spaces. Im not saying youre all wrong just wrong with eth-glycol which is the main coolant used in older motors. new stuff it's a toss they have so many new "organic" formulas.
  6. Jul 31, 2014 at 10:36 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Everything I have ever heard or read on coolant says water will cool more effectively than having the additives. Plain water will cause rust to happen though. The additives are to help in rust prevention, and give the mixture a greater range of temperature as liquid, rather than allow boiling or freezing.
    I don't have anything to offer than hasn't already been said on lack of cooling for the bike though.
  7. Jul 31, 2014 at 8:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you re-read the original statement, username said 'properly mixed coolant' he did not say 'straight coolant'. Big difference IMO.
    Properly mixed coolant, typically a 50/50 mix with water, lubricates the waterpump, lowers the freezing point, raises the boiling point and effieciantly transfers heat. A water/coolant mix is superior to straight water.
  8. Jul 31, 2014 at 10:44 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    ^^^ Agreed....
  9. Jul 31, 2014 at 11:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    that is basicially the opposite of what I have been hearing. Water is a more effective than coolant. A 100% water "mix" will cool better than a 50/50 as EG reduces the boiling point. The difference is the straight water will freeze, which is of course a problem in the winter so you need a mixture of "coolant" to prevent that.
    I love how something as simple as coolant is still up in the air:rolleyes:
  10. Aug 1, 2014 at 6:24 AM
    BradyT88
    BradyT88 Well-Known Member
    Coolant doesn't prevent water from freezing. It prevents it from boiling. Antifreeze prevents it from freezing. Ethylene glycol is usually the antifreeze component. Not sure what the coolant component is off the top of my head.
    But as you guys are, most people use the terms coolant and antifreeze interchangeably since both are mixed together in normal use.
    I was browsing around for antifreeze without coolant in it for my ORI's since they called for ethylene glycol a while back. Ended up just running fork oil.
  11. Aug 1, 2014 at 7:03 AM
    rctoy
    konstantenos
    Pocatello Idaho
    I reread his comment and the argument still stands. Water transfers heat better than coolant/anti-freeze mixture does. even properly mixed "coolant" does not transfer heat as well as just strait water. I looked at towing temps on my cummins and then changed the mixture to 40% "coolant" and 60% water. Same day same outside temp same load same road yet I ran 10 degrees cooler. that's just one personal example I have. all the boys down at the race track will tell you the same thing. hell just read the back of the bottle of any additive designed to help drop coolant temps.
    Edit: I do agree that a properly mixed coolant lubricates the WP better than just strait water and does effect the boiling/feezeing point greatly
  12. Aug 1, 2014 at 9:57 AM
    rctoy
    konstantenos
    Pocatello Idaho
    ben just settled it. right there put the rad in the arb fridge and bam over heating issues solved. LOL
  13. Aug 1, 2014 at 11:16 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I went to like 95%water and additive and it still overheats. I need to put the whole engine in the arb fridge lol
  14. Aug 1, 2014 at 12:03 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Seriously look at your fuel air mixtures and your timing. if those two things get out of wack they will cause hell on your cooking system that and running lean is really hard on vavles
  15. Aug 1, 2014 at 1:23 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I'm not sure exactly how to do both of those things.
    I couldn't find any timing marks on the crank bolt, and I'm assuming the air fuel mixture is going to require taking the carbs at less somewhat apart
  16. Aug 1, 2014 at 1:32 PM
    rctoy
    konstantenos
    Pocatello Idaho
    there may not be any. might just be a flywheel with pick up coil, in which case just make sure the key way is in good shape. as far as the carbs go I use a 5 gas analyzer and I know you don't have one of those so might be a good idea to do some research on the jetting of them and whats right for your elevation.
  17. Aug 1, 2014 at 3:37 PM
    Smar969905
    Zach
    Deer Park, WA
    Reroute the AC lines so the cold side hits the block, then goes to a custom sealed radiator, then back to the compressor, and have a temperature controlled switch for the compressor start/stop.
  18. Aug 1, 2014 at 3:47 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    You can quick check your jetting by pulling a spark plug and looking at the color. Cardboard brown=perfect
    White and nuked looking=lean
    Black and smelly= rich
    Timing is probably fixed if it has a CDI box (electronic ignition). If it has points it is adjustable.
    I had a CR250 that overheated like a mother and I couldn't figure out why. Turns out when I washed it at the carwash I sprayed the mud off the radiators and
    it bent the fins. It just wasn't getting air flow. Have a look at the fins, you should be able to see right through them if you look at the right angle.
  19. Aug 2, 2014 at 9:17 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Been raining for 2+ hours here. Stupid
  20. Aug 2, 2014 at 9:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Why? Are you concerned it may turn green? :D
