Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 21, 2014 at 10:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    could be any one of the 4 bearings too.
  2. Oct 21, 2014 at 11:04 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    This also is true..also coming to realize I dont have stock gearing...
    I dont think the previous owner even knew this...
  3. Oct 22, 2014 at 7:02 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    in all honesty it might not even be a bearing in the diff could be a wheel bearing or a bearing in the transfercase that eco's down the drive line. that's why I said play with it. what speed does the the noise happen? on excel decel or what? does it change when truning right or left? need to know these things.
  4. Oct 22, 2014 at 10:00 AM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    No change when turning..just when accelerating..doesnt seem like their is any noise on decel at all.
  5. Oct 22, 2014 at 10:14 AM
    BradyT88
    BradyT88 Well-Known Member
    Mine would make noise on decel if I downshifted. If I just let off the throttle and kept it in drive it would make noise, but it was pretty quiet and hard to notice. If I put it in neutral the noise completely disappeared and if I down shifted it got much louder. It was also pretty loud under accel.
  6. Oct 22, 2014 at 10:54 AM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    See that sounds like what I have, but if there is any decel noise its very minimal, almost impossible to hear. Sounds more like the noise you would hear gearing down from higher speed as it slows. No noise in neutral at all, loud under higher speeds when accelerating.
  7. Oct 22, 2014 at 11:51 AM
    rctoy
    konstantenos
    Pocatello Idaho
    well thus far im back to thinking it's a gear set up issue or a side bearing issue. there's a rare chance you could have a warped housing causing problems but who knows.
  8. Oct 22, 2014 at 12:14 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Well if the ring gear and pinion have been checked and changed multiple times already that would somewhat indicate that that wouldnt be the issue, wouldn't ya say?
    Unless the locker itself is faulty.
    Haven't had any real opportunity to fully test it out.
  9. Oct 22, 2014 at 12:55 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Arb's only make one noise when they fail.. BOOOOMMMM!!!!!!!!
    it's not he locker. and I guess it depends on who was setting up the gears or if the housing is warped like I was saying.
    silly 8" rear ends anyways.
  10. Oct 22, 2014 at 1:55 PM
    BradyT88
    My factory ring and pinion blew up on me and I had it fixed under warranty by a local mechanic since I was over 60 miles from a delaership at the time. They made his use all Toyota OEM parts and I got about 800 miles on it before it started making the noises. After putting it on jackstands and confirming the noise was coming from the rear diff; Brant and I pulled it and found a small chip in the ring gear (though it was on the edge and didn't come in contact with the set pinion pattern so I don't think it was causing the noise). After finding that I just said fuck it and ordered an already set up third from ECGS so I got a different third and it has been fine for the last 15K miles now. Because of that I never did find out exactly what was making the noise but we suspected the pinion bearing because fuck crush washers... My ECGS diff uses a solid spacer.
  11. Oct 22, 2014 at 4:38 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Well shit I hope its not that.
    Hopefully my buddy gets back to me about using his jacks to lift the girl up...see if i cant get to the bottom of this. I just want to find out what it is before something bad happens lol
  12. Oct 22, 2014 at 4:50 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Where in MT are you? I have a pair of jack stands and a hydraulic jack. I'm north of Spokane, WA
  13. Oct 22, 2014 at 4:56 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Im in butte, my friends have a few I can use. Just waiting to hear if we can do it in his nice garage so im not in the middle of the road doing it lol.
    Someone mentioned that there was 4 bearings I should double check as well?
  14. Oct 22, 2014 at 5:06 PM
    Smar969905
    Zach
    Deer Park, WA
    Probably RCtoy. I want to say he lives in south ID.
  15. Oct 22, 2014 at 5:34 PM
    BradyT88
    Yep. He's in Pocatello.
  16. Oct 22, 2014 at 5:36 PM
    rctoy
    konstantenos
    Pocatello Idaho
    for now but im gonna move far away and have so OHV parks to play in. :D
  17. Oct 22, 2014 at 5:43 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    So about those bearings? 4 of them?
  18. Oct 22, 2014 at 5:43 PM
    BradyT88
    Traitor!:brianr:
  19. Oct 22, 2014 at 7:37 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  20. Oct 23, 2014 at 7:00 AM
    rctoy
    konstantenos
    Pocatello Idaho
    yeah two pinion bearings one big one and a little one and then carrier bearings both will be the same size. inner and outer bearing need to be looked at with a fine tooth comb. anything that looks like a pit in any part of the bearing and it's junk.
    Ahhh dude snow wheeling to the max.
