Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Nov 17, 2014 at 9:11 AM
    BradyT88
    BradyT88 Well-Known Member
    I noticed that with my car last week. Was a little sluggish starting but it started fine. Shifting gears sucked balls though. It particularly didn't like going into 2nd gear, it took a little bit of fight.
  2. Nov 17, 2014 at 9:26 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I have a remote start and dual red tops :cool:.
  3. Nov 17, 2014 at 9:27 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I took it off this summer. It did a good job of heating the trans oil, but the clutch was still extremely sluggish. I wonder if they make lighter weight dot4 or something that does better in the cold. I run mineral oil in my KTM's hydraulic clutch. That might work?
  4. Nov 17, 2014 at 9:43 AM
    rctoy
    konstantenos
    Pocatello Idaho
    they also make a synthetic high temp dot 3 that performs as well as dot 4. I use it for my breaks and it works great.
  5. Nov 17, 2014 at 10:09 AM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    -10 this morning and started like a champ.
    I don't have a block heater but they are definitely nice to have.
    Really need to look at a remote start.
  6. Nov 17, 2014 at 8:17 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Alright guys. Need some opinions on a new front bumper. Looking at a tube bumper. Dont want the TG cause it doesnt suit the 95-97 models very well. Dont really want a plate bumper either unless the Apex goes on sale
    Also looking at upgrading the front end suspension. Thinking OME or SAW. Obviously SAW is the way to go but not sure i want to put $800-$1000 on suspension right now. Maybe 882 and nitro sports?
  7. Nov 17, 2014 at 8:21 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Why not saws? I don't see why putting in more money is an issue..adding OME is just going to add to the total overall cost
  8. Nov 17, 2014 at 8:25 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I would love to get them but im in need of some new suspension soon. My billies have over 100k kms and the toytec coils are just too stiff and causing all my front end components to fail prematurely. The OME is a softer ride, no? Maybe i could do some saws, the 2.0s are only $700 right now.
    Plus if i went ome, i would drop the saws altogether
  9. Nov 17, 2014 at 8:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you got a bumper the eibachs would ride much better. Heavier the better.
    Saws are rebuild able. OME is a throw away. Will last a bit longer possibly then the billies.
    Not like you need 2.5s. Just get the 2.0s
  10. Nov 17, 2014 at 8:58 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    I have OME shocks on my runner and I have to admit the ride is great. Super smooth on and offroad. Of course all the weight helps.
    I have the same view as Ben, eventually I will probably upgrade them to an extended length, thinking icons, but until then its working just fine.
  11. Nov 17, 2014 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It isn't the coils that are causing the stiffness you are experiencing. It is the billies.
    The least expensive choice for you would be to continue to run the toytec/eibach coils with new struts. When you add the aftermarket bumper you will need, at the very least, the 620# coils you have now.
    However, IMO, the advantage of adjustability outweighs all the other reasons for upgrading the coilovers. The SAW 2.0s are an inexpensive option to get that adjustability. They are plenty of shock for our trucks and come with 650# eibach coils.
    I would still be running SAWs if I could have run 700# coils with them. Your truck weighs a lot less than mine, you'll be fine.
  12. Nov 17, 2014 at 10:31 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Girlfriend just left a 12 pack of Bluemoon, two oranges, a new beer glass from the college, and a $30 gift card to game stop with a note saying have a beer and game on her on my patio....I feel like this is a trap lol
  13. Nov 17, 2014 at 10:41 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Beware!!!!!!!!!!!!!!
    She's prego's :facepalm: ;)
  14. Nov 17, 2014 at 10:45 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Dude...why would you put that on me lol
    I think she got the idea from the Chive today
  15. Nov 17, 2014 at 10:49 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Seriously, if she were, you would know by now. They can't keep that type of thing a secret for as long as it would take you to get through a 12 pack.
    Mine couldn't even wait till I kicked my boots off and her shoes. Literally, came in the door and blurt it out. No, "hey honey, heres a beer", nothing. your fine. I was just busting your balls.
    It turned out to be a false alarm for me, in case you were wondering. :thumbsup:
  16. Nov 17, 2014 at 11:10 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Good news for you lol haha im not ready for that. She does spontaneous little things for me every now and then, kinda nice
    Those are among the more often spontaneous things:cool:
    I could probably work that in while playing the game I buy and having a beer
  17. Nov 18, 2014 at 12:28 AM
    skygear
    skygear                    
    One guy clapping in the crowd
  18. Nov 18, 2014 at 12:31 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You're done for.
  19. Nov 18, 2014 at 11:51 AM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    That took my longer to find then I care to admit lol
    you shut up and go answer my email!!!!
  20. Nov 18, 2014 at 5:40 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    She said she just wanted to be nice...
    Still think somethings up lol
