Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 11, 2015 at 11:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, I'd be cool with that. Let me talk with my buddy to make sure he's cool with it. I'll send you a pm tomorrow.
  2. May 12, 2015 at 12:44 AM
    Greddy
    Greddy Would you eat the moon if it were made of ribs?
    Cam
    Bonney Lake, WA
    It's a Tacoma, white n black, DCLB
    Front & Rear HC Bumper with Swing Out, Full Skids, Icon CO's and UCA's, Dakar w/AAL, Icon Rear Shocks and U-bolt flip, w/Superbumps. 17" XD Wheels, 34" BFG KM3s, CB/Ham Radio, 10% Tint, Snugtop, WeatherTech Mats and Deflectors, Rigid Fog Lights, UltraGauge, TRD Seatcovers, On-Board CO2 and 20L fuel. Roof Top Tent. AirFlow Snork, smittybilt winch, 20" light bar.
    Sounds good
  3. May 12, 2015 at 7:42 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Wheelers just told me i could put some OME front struts with my Eibach's. Would that be a smoother ride than 5100s? Thoughts?
  4. May 12, 2015 at 8:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can yes. The older nitro chargers would probably be a bit smoother. Probably not huge difference though.
    Biggest thing you need is weight. You have 620lb rate coils and no front weight. That's your main problem.
  5. May 12, 2015 at 8:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I've not run OMEs so take this feedback with the proverbial grain of salt.
    In the short term they might be fine but I think there is a possibility that the 620# Eibach coils will be too much in the long run for the nitrochargers, just as they are too much for RCD Bilstein 5100s. The nitrocharges are designed for a 500# coil.
    @scocar Some people have been fairly vocal about their experience with this combination. :notsure:
  6. May 12, 2015 at 8:33 PM
    BradyT88
    BradyT88 Well-Known Member
  7. May 12, 2015 at 8:34 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Ok, which models are they? Not the sports?
  8. May 12, 2015 at 8:38 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  9. May 12, 2015 at 8:52 PM
    BradyT88
    The 450 almost doesn'thave enough go. 4th gear tapped out and he loses a lot of speed going into it.
  10. May 12, 2015 at 9:04 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Is N94 the part #?
  11. May 12, 2015 at 9:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Again though...
    You need front end weight. Otherwise the springs are too stiff
  12. May 12, 2015 at 9:30 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I know i need more weight up front but i need to do something quick cause my front end components are getting pounded
  13. May 12, 2015 at 9:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Shorter coils though too. Less preload.
  14. May 12, 2015 at 9:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Your using examples of coils he doesn't have and shocks he can't buy. :facepalm:
  15. May 13, 2015 at 9:31 AM
    Manwithoutaplan
    ID
  16. May 13, 2015 at 9:34 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
  17. May 13, 2015 at 9:36 AM
    BradyT88
    The most height I've ever seen him catch! He's sunk a lot of money into that bike and has the suspension tuned pretty well and that was bottoming out the bike even landing on a steep down slope. We debated parking my Taco there for him to jump. We're pretty sure he would even clear my whip but we decided it was too risky to try. Haha
  18. May 13, 2015 at 9:37 AM
    Manwithoutaplan
    ID
    That is what i was wondering :notsure: . I have tried to text him a couple time but no response. I know He is going to las vegas to marry a family friend or friend.
  19. May 13, 2015 at 9:38 AM
    Manwithoutaplan
    ID
    not about the parts it is about [​IMG] yam bags to do the jump.
  20. May 13, 2015 at 9:49 AM
    BradyT88
    It's both at that point. Haha I guarantee if you tried that on my stock bike you'd break your face on the handle bars.
