Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 19, 2015 at 8:42 AM
    BradyT88
    BradyT88 Well-Known Member
    It just holds the shifts longer (and possibly blocks out overdrive) for towing. It would make a difference for normal driving but you get the same effect just putting the throttle to the floor. haha
  2. Sep 19, 2015 at 9:23 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It does not keep it from shifting into overdrive. We have a separate button for that.
    When the ECT is on, all it does is raise the RPM shift points by a couple hundred RPMs. Mine is always on. Ha!
  3. Sep 19, 2015 at 10:42 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    exactly, I knew it upped the rpms on shifts, so you only tell a difference if you are getting on it while driving
  4. Sep 19, 2015 at 12:01 PM
    Tacoma.Gal
    Tacoma.Gal Let's Go Places
    Shelby
    Boise, ID (WA Import)
    '98 Tacoma TRD PreRunner
    Alpine Stereo, Clear headlights
    Wait. Getting on it while driving isn't a normal behavior? :rolleyes:
  5. Sep 21, 2015 at 2:18 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Last time I ever let my girlfriend try and load the quad into my truck....
  6. Sep 21, 2015 at 3:54 PM
    Manwithoutaplan
    ID
    Damn that sux :/.
  7. Sep 21, 2015 at 3:58 PM
    BradyT88
    Oh shit! My understanding is that you can't replace just one of those. You have to do the whole back window as a unit and it ain't cheap...
  8. Sep 21, 2015 at 5:38 PM
    DirtyTeRD
    DirtyTeRD Well-Known Member
    Steven
    Ohio
    Black 07 TRD
    BlackMAXX Tonneau, Toytec 3in 5100s with eibach coils, Toytec BOSS leafs, LR UCAs, Relentless fab diamondplate tailgate cover, lowes slimline toolbox, pelfreybilt bed bar
    Fuk that sucks
  9. Sep 21, 2015 at 8:08 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Hey all I'm out in Boise for the week for work and am considering blowing tomorrow off. Can anyone recommend a good place for a dayhike in the Boise area? Thanks
  10. Sep 21, 2015 at 8:56 PM
    DirtyTeRD
    Steven
    Ohio
    Black 07 TRD
    I'm not in Boise but I have been told that table rock is a good day hike. I haven't been yet though.
  11. Sep 21, 2015 at 9:50 PM
    Manwithoutaplan
    ID
    how did the first day go?
  12. Sep 21, 2015 at 9:51 PM
    Manwithoutaplan
    ID
    i would say screw the day hike and head to mccall.
  13. Sep 21, 2015 at 11:22 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I don't hike much, i MTN bike. How difficult are you looking for? A friend did a trail called stack Rock and he said it was about 9 miles and not a beginner trail.
    The foot hills and the ridge to rivers trail system is fun, but it's Stil in the foothills and is brown. There is always the hike to table rock if you want a pretty short trail, maybe 45 min one way? Haven't done it in forever. But you can also drive to table Rock and skip the hike. If you're in boise my vote usually goes for a hike or mtn bike ride up at bogus.
    That is a very good option haha.
  14. Sep 22, 2015 at 6:11 AM
    tacomakid96
    Phil
    Out n' about
    ya it was really hard not to loose my temper,
    So far ive seen its all one piece, you can replace the slider but not the right pane. Every glass place wants $700 plus so I found one off ebay for $200 and a guy in town that will install it for $125
  15. Sep 22, 2015 at 6:32 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Thanks. Looking for something moderately difficult. Think I'm just going to hit one of the ranger stations in the National Forest and go from there.
    I have seen table Rock mentioned around the interwebz, 45 min is a bit short. I was looking for more like 1/2 the day or more
  16. Sep 22, 2015 at 12:33 PM
    Idaho TRD
    Idaho TRD Well-Known Member
    Robert
    Idaho
    15 tacoma trd off road 4x4
    Is this enough cut for 35's or should I do more. Haven't tested yet that's why I'm asking
  17. Sep 22, 2015 at 4:19 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Probably not for full stuff and lock to lock
    Can almost guarentee it
  18. Sep 23, 2015 at 6:55 PM
    Idaho TRD
    Robert
    Idaho
    Has anyone hit the trail double headed dragon up at the owyhees? What is the difficulty lol of it?
  19. Sep 23, 2015 at 7:43 PM
    Manwithoutaplan
    ID
  20. Sep 23, 2015 at 8:13 PM
    Tacoma.Gal
    Shelby
    I go. It's cheap entertainment. I enjoy them quite a bit. There's only like 1 or 2 left this season.
