Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 1, 2016 at 2:48 PM
    Manwithoutaplan
    ID
    Mark pm your phone number so we can off road on sunday.
  2. Jan 1, 2016 at 11:07 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Doin the tear down... Pinion flange is wobbly as hell. Looks like the culprit!
  3. Jan 2, 2016 at 12:38 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Blown pinion? Sheesh.
  4. Jan 2, 2016 at 9:09 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is that your orginal diff? Did you regear it?
  5. Jan 2, 2016 at 9:19 AM
    BradyT88
    BradyT88 Well-Known Member
    I believe it's the original since he has factory 4.56's, but he did just put an ARB in it in the spring.
  6. Jan 2, 2016 at 9:40 AM
    Manwithoutaplan
    ID
    anybody want to go snow wheeling in boise :pray: i have been dying to go.
  7. Jan 2, 2016 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did you check the gear setup when you put the arb in it? You know that the backlash changes when that happens right?
  8. Jan 2, 2016 at 2:55 PM
    Manwithoutaplan
    ID
    hate you :smack:
  9. Jan 3, 2016 at 10:14 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    7 hours till I go rage in jackson hole for the week
    good bye liver
    BradyT88 likes this.
  10. Jan 4, 2016 at 6:10 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I did the set up for him and yeah i made sure the back lash was good. Diff did great in moab and never made a noise. My guess is running a front tire low in 4x4 at speed on the read had the rear diff over driving the front and that put a lot of load on the pinion bearings causing high diff temps and premature wear.
  11. Jan 4, 2016 at 6:49 AM
    Tacoma.Gal
    Tacoma.Gal Let's Go Places
    Shelby
    Boise, ID (WA Import)
    '98 Tacoma TRD PreRunner
    Alpine Stereo, Clear headlights
    The taco started making a horrible squealing yesterday, started back up again this morning. I'm pretty sure it's not a belt because it sounds like it's coming from the rear and it only makes the sound when I'm moving, can't get it to squeal when I'm parked. Seems to only happen between 1k-2k RPM and seems to get better when I accelerate and worse when I take my foot off the gas. Could it be a frozen brake maybe? I park in the garage so it's not like it gets that cold. :confused::(
  12. Jan 4, 2016 at 7:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's a u joint
  13. Jan 4, 2016 at 7:13 AM
    rctoy
    konstantenos
    Pocatello Idaho
    with a ujoint that makes noise usually comes play and vibration.
  14. Jan 4, 2016 at 7:23 AM
    Tacoma.Gal
    Shelby
    Sounds expensive. There does seem to be some vibration when braking, but I figured that was just my brakes.
  15. Jan 4, 2016 at 8:47 AM
    rctoy
    konstantenos
    Pocatello Idaho
    vibrations while braking is not a U-joint and U-joints are cheap, unless you're paying some one like me to do them. The good news is problems don't get better they get worse so it's going to get easier to find and more expensive. Just ask Mark.
  16. Jan 4, 2016 at 8:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine didn't. Just screamed just like what she says. Thought it was the carrier bearing and it wasn't. Just the rear U joint.
  17. Jan 4, 2016 at 8:53 AM
    Tacoma.Gal
    Shelby
    Sounds like I'm going to have to take it in for diagnosis.
  18. Jan 4, 2016 at 9:17 AM
    Tacoma.Gal
    Shelby
    Taking her to Toyota on Wednesday.. I like burning money :(
  19. Jan 4, 2016 at 11:16 AM
    Manwithoutaplan
    ID
    Find a drive shafts place they will be cheaper than stealyota.
  20. Jan 4, 2016 at 11:18 AM
    Manwithoutaplan
    ID
