Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Aug 30, 2017 at 5:50 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Im actually in utah at the moment. I stopped at a Cabelas down in SLC but apparently the only way to get one is to order it from the website unfortunately.
  2. Aug 30, 2017 at 9:20 PM
    Tacoma.Gal
    Tacoma.Gal Let's Go Places
    Shelby
    Boise, ID (WA Import)
    '98 Tacoma TRD PreRunner
    Alpine Stereo, Clear headlights
    Anyone going to the balloon classic this weekend? Kind of sad I'll be missing it this year.
  3. Aug 30, 2017 at 9:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    My little brother probably is lol. He works with one of the balloon crews. I'll be paddleboarding the Boise so I'll get to see a bit of it me thinks
  4. Aug 31, 2017 at 6:15 AM
    boiseroadtrip
    boiseroadtrip Well-Known Member
    B
    Boise
    2017 TRD Off Road DCSB
    Bone Stock
    We got here in February. Had over a foot of packed ice at the curb and 4 inches of ice on the driveway. After clearing the ice from the driveway, it wasn't that bad. It did snow on us a couple of times. But not much.
    When the moving truck was full it did rather well on the ice. Empty was a completely other story. It's amazing what 10,000 lbs does to improve traction on ice.
  5. Aug 31, 2017 at 9:11 AM
    boiseroadtrip
    B
    Boise
    Bone Stock
    Our landlord shoveled or driveway at least once before we got there.
    Sometimes neighbors can be so inconsiderate. At that house they where nice. Loaned me a snow shovel and an ice breaker to clear the ice and offered to help unpack the truck.
  6. Aug 31, 2017 at 9:59 AM
    boiseroadtrip
    B
    Boise
    Bone Stock
    I should have said that people can be inconsiderate, was up on Boise ridge last night to watch the sunset. Drove down a trail to a little knoll. Some guy in a f-150 decided to park in the trail and block me in. After 30 minutes waiting and looking for them, I went off roading. Luckily The FJ has enough ground clearance to make over the rocks that were put ther to keep people on the trail.
    Hope you guys get some nice neighbors.
  7. Aug 31, 2017 at 10:52 AM
    boiseroadtrip
    B
    Boise
    Bone Stock
    Yeah, well I was pretty lit. Just didn't want to go off the trail. I also wanted to find em so they would be aware of the problem in the future. Unfortunately, I didn't have pen and paper. Otherwise I would have left them a note.
  8. Aug 31, 2017 at 5:17 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Make sure you're outside holding guns and letting the dogs run loose when new neighbors arrive. Also try to use choice redneck language, tone of voice, and volume. Should help them want to not be around for long.
    Drive around them furst, then cut the valve stem off of the driver front tire. Tire goes flat, and if the jackass is semi prepared, has compressor, and quickly finds the cut stem, and might get the message. Only damage done is to the stem and not the tire, whi ch forces the douchebag to have the tire dismounted, then remounted which may result in a charge to them by tire place.
    You could be a bigger asshole and carry a glass cutter with you, then cut the windows. Won't necessarily show right away, but come winter, the heat and cold will cause the cuts to break through and windows open up.
    Remove lug nuts or just loosen lug nuts.
    Break window(s). Slash tire(s). Remove drain plugs from differentials, transfer case, transmission, oil pan.
    All depends on how vindictive you feel.
  9. Sep 1, 2017 at 7:21 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    you forgot pouring a couple pounds of sugar in the fuel tank
    Grease the wiper blades and door handles
    Fill the exhaust pipe with spray foam
    or smearing human excrement across the windshield
    or just take a dump on the middle of the hood
    Lots of options to keep new neighbors in line
  10. Sep 1, 2017 at 7:51 PM
    JennJenn
    JennJenn Remembering Rick ❤
    Jenn aka (dzzyneon)
    Boise, Idaho
    2021 Army Green Trd sport dclb!!~Sold~2008 Indigo ink TRD Sport DCLB!!
  11. Sep 1, 2017 at 10:02 PM
    Smar969905
    Zach
    Deer Park, WA
    Yeah, I forgot about some of those. Use deodorant on windshield wipers. That is designed to stay in place better.
    On excrement, smear it on the door handles.
    And that sugar may not go down the pipe to the gas tank, so pour some water down to help it.
    Not everybody carries expanding foam with them for an off-road excursion.
    I finally have a stalker... I've been waiting all my life for this too.
    Let them know that blocking a driving path isn't right. Unless that thing can't move without risking damage, roll it at least half way off the path. Not that hard to put a vehicle in neutral and roll a little.
  12. Sep 2, 2017 at 9:10 AM
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    I too have always wanted a stalker!! Well a good looking one that's not too creepy anyway. I always get the creepy ones... Lol
  13. Sep 2, 2017 at 9:20 AM
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    So anyone in here close to meridian/Boise that can help me out with my truck at times? Long story but no tools or garage anymore so I'm just looking at my options. I don't really know many good mechanics that won't rip you off around here and I can only work on so much in the parking lot of my townhome. Any recommendations also would be great. I recently left the old man of 22 years and starting over again with life, long story short.
    m3bassman likes this.
  14. Sep 2, 2017 at 12:48 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    22 is a long time...
    JennJenn likes this.
  15. Sep 2, 2017 at 1:55 PM
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Yep, and I'm a million times happier now than I have ever been..
    wilcam47[QUOTED] and m3bassman like this.
  16. Sep 3, 2017 at 2:23 PM
    wilcam47
    Will
    Bourbon state
    well everyone has their own level of what they can put up with.
    JennJenn[QUOTED] likes this.
  17. Sep 3, 2017 at 4:07 PM
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Yeah, my level should've put up a long time ago...
    wilcam47[QUOTED] likes this.
  18. Sep 3, 2017 at 5:36 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I guess I should use this thread more often now. Ran out to red river/dixie area yesterday to check out the fishing. Ended up buzzing up the magruder corridor for a bit. Visited the green mountain lookout and let the pup get some sun.
    [​IMG]02SEP2017 by Gage McKeag, on Flickr
    wilcam47, m3bassman and Aussiedogs1 like this.
  19. Sep 3, 2017 at 5:44 PM
    Aussiedogs1
    Aussiedogs1 Well-Known Member
    SW Montana
    2013 TE 4runner
    Dang nabbit. Just got back from there must have just missed seeing ya on the trail:(. Good looking Yota :thumbsup:.
    BabyTaco[QUOTED] likes this.
  20. Sep 3, 2017 at 6:03 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    This was on Saturday. Are you in this area often?
