Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 25, 2018 at 6:57 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    ouch, that looks painful...
  2. Mar 25, 2018 at 7:18 PM
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    Damn man! Sorry to hear that! Can’t wait to see what you come up with tho
  3. Mar 25, 2018 at 7:38 PM
    Manwithoutaplan
    ID
  4. Mar 26, 2018 at 9:27 AM
    Datin Metal Fabrication
    Datin Metal Fabrication Well-Known Member
    Ed
    Weiser, Idaho
  5. Mar 28, 2018 at 7:58 PM
    wilcam47
    Will
    Bourbon state
  6. Mar 29, 2018 at 7:32 PM
    jaydeezy661
    jaydeezy661 Active Member
    Sam
    Bakersfield, CA
    2000 tacoma 4x4 xtra cab with RR Dif lock
    mostly stock so far, recent addition are front wheel spacers to fit a set of 265/75r16 Wrangler Authority tires.
    anyone wanna go hit some trails and camp sometime soon ? im in and around Boise area.
    prodeer and wilcam47 like this.
  7. Mar 30, 2018 at 5:47 PM
    jaydeezy661
    Sam
    Bakersfield, CA
    I tried to look for info online but couldn’t really find any. But does anyone know whether a 1990 pickup front bumper fit a 2000 tacoma ?
  8. Mar 30, 2018 at 5:56 PM
    Ed
    Weiser, Idaho
    I don't think it will. Years 95-04 have the same front frame mounts.
    wilcam47 likes this.
  9. Mar 30, 2018 at 6:27 PM
    jaydeezy661
    Sam
    Bakersfield, CA
    oh okay thank you. thats what I was thinking.
  10. Mar 31, 2018 at 8:31 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    95.5-97, 98-00, and 01-04 all have different frames. If you need a bumper for your 00, only 98-00 will bolt up easily
  11. Mar 31, 2018 at 8:33 AM
    Ed
    Weiser, Idaho
    Yes, these require cutting the first 3.5" of the frame horn back and welding in a nut plate. Easy to install from there but not many people have welders.
  12. Mar 31, 2018 at 8:35 AM
    pittim
    Pennsyltucky
    Boujee Prius
    Yeah, really sucks when you buy something designed off of the 98-00 and realize you need to extend your frame horns to make it work..
  13. Mar 31, 2018 at 9:02 PM
    sr20fastback
    sr20fastback Well-Known Member
    Allan
    Eagle, ID
    ‘18 MBM Pro
    all of them
    Did I spot JennJenn on my way back from Grit on Eagle around 5-5:30ish today?
  14. Apr 1, 2018 at 8:11 PM
    boiseroadtrip
    boiseroadtrip Well-Known Member
    B
    Boise
    2017 TRD Off Road DCSB
    Bone Stock
    I would be up for this, but time is really tight right now. At the end of the month or the beginning of May.
  15. Apr 1, 2018 at 8:12 PM
    boiseroadtrip
    B
    Boise
    Bone Stock
    Whoa, that looks bad. Hope there’s not any lasting injury.
  16. Apr 1, 2018 at 8:27 PM
    Ed
    Weiser, Idaho
    I'm out for 6 weeks at the very least on camping. More realistically the next few mo the surgeon says my 100% rehab time table is 9-12months. Thankfully it's my left shoulder and I'm right handed haha.
    wilcam47, Just Dandee and austin2009 like this.
  17. Apr 2, 2018 at 8:47 AM
    wilcam47
    Will
    Bourbon state
    yikes. I'd have to cry if I was out that long...;)
  18. Apr 4, 2018 at 9:25 PM
    Ed
    Weiser, Idaho
    If it's been recently, no. My truck has been in the garage since I got hurt a couple weeks ago. I do live in between Franklin and Fairview on 5 mile so if you've just seen me around there than probably haha.
  19. Apr 5, 2018 at 7:31 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Holy shit that’s intense. From a green cat track? Ugh, fuck those things. I way over rotated my right shoulder very beginning of the season coming up short on a jump and it’s still not the same. Not sure if I need to rehab it and keep stretching or if I’m just screwed with how it healed. If I hold my arm straight out and rotate left, inward, is the problem direction and does not feel good. It also slightly gets reinsured every time I fall hard on it
  20. Apr 5, 2018 at 8:28 AM
    Ed
    Weiser, Idaho
    Yeah it was wild I hit a little side birm and did a little 180. The snow was kind of hard and icy and when I went to spin back around I caught an edge and planted my shoulder into the ground. It gave me a grade 5 shoulder seperation (tore 3 ligaments) and the ligament tearing was so violent that it splintered my collar bone when they finally tore. It was a super freak accident. This time tomorrow though I'll be cut up, plated, and screwed back together haha. Hopefully I get to keep my full collar bone haha
