Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 27, 2012 at 12:10 PM
    #6781
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Nah, dont worry about it. You dont need it.
    "Sway bars are like condoms. Its safer with them, but more fun without" :cool:
  2. Mar 27, 2012 at 3:30 PM
    #6782
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    well its all done. ill post pics later. dealing with a girl fiasco now.
  3. Mar 27, 2012 at 4:29 PM
    #6783
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well I left the sway bar off... if me and my gf die toinight in a fiery rollover I'm blaming you guys.
  4. Mar 27, 2012 at 4:31 PM
    #6784
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Also girl problems were because of truck. So wouldn't work, but eh, it had to be done. Lol. I couldn't leave it there on jack stands a whole day
  5. Mar 27, 2012 at 4:33 PM
    #6785
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    No, not that, almost as trivial, but not like that lol. That was just my thoughts as I'm drivin it
    Ill explain later lol
  6. Mar 27, 2012 at 5:06 PM
    #6786
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    you'll be better off than be w/o a sway bar because you aren't on factory suspension. I don't run one either, it's sitting in my yard collecting rust.
    yea I'm a redneck
  7. Mar 27, 2012 at 5:32 PM
    #6787
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    Front and rear diff being installed Thursday! BOOOOOM!
  8. Mar 27, 2012 at 6:59 PM
    #6788
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sick:cool:
    very jelly!
  9. Mar 27, 2012 at 7:07 PM
    #6789
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not a whole lot...okay thats a lie..but doing alright haha
    Hows it hanging??
  10. Mar 27, 2012 at 7:12 PM
    #6790
    Blackdawg
    Monte
    Wyoming/St. Louis
    idk..its pissing me off tho..i don't want to pull what another MT meet either..especially that far from home..
  11. Mar 27, 2012 at 7:17 PM
    #6791
    MTgirl
    Weesa
    Bob's secret mod lair
    Plus I don't think you're dad's going to want to drive that far....again....:rolleyes:
  12. Mar 27, 2012 at 7:18 PM
    #6792
    Blackdawg
    Monte
    Wyoming/St. Louis
    most likely not :p haha
  13. Mar 27, 2012 at 7:54 PM
    #6793
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    we need to get our trucks together ASAP
  14. Mar 27, 2012 at 7:58 PM
    #6794
    BradyT88
    BradyT88 Well-Known Member
  15. Mar 27, 2012 at 8:02 PM
    #6795
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  16. Mar 27, 2012 at 8:07 PM
    #6796
    Blackdawg
    Monte
    Wyoming/St. Louis
  17. Mar 27, 2012 at 8:10 PM
    #6797
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes you slowly undo the clamps
    the old pin will just come out.
    put in the the aal
    put in the new bolt
    slowly clamp back down and keep the leafs lined up.
    bolt down the leaf bolt.
    bolt up the Ubolts
    and your basically done.
  18. Mar 27, 2012 at 8:11 PM
    #6798
    Blackdawg
    Monte
    Wyoming/St. Louis
    no worries man :D
    was a good find none the less. and i want 10'' wide rims this next go around.
  19. Mar 27, 2012 at 8:13 PM
    #6799
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes it does. You will have to undo the nut on the top of course.
  20. Mar 27, 2012 at 8:14 PM
    #6800
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you are correct. the centering pin will fall out fairly easily.
    once the AAL is in you need to clamp the leafs back together
    then tighten down the centering pin
    then put the Ubolts on and torque them BEFORE YOU REMOVE THE CLAMPS
