Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 6, 2012 at 8:06 PM
    #7861
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Howd this turn out?
    My SD card stopped being recognized on my evo too. Got it back long enough to back up all my contacts and stuff by hard shutdown and restart but then it did it again a few hours later.
    To fix mine permanently (at least for now) it required a factory reset. You can do it yourself from within the phone. Menu>Settings>SD & Phone Storage>Factory Data Reset.
    I also synced to the PC and backed up everything on the card and then formatted the card then put the backup back into the card. Not sure if reformatting was required but I did it.
    Its working now. This was about 10 days ago when it happened.
  2. Apr 6, 2012 at 8:10 PM
    #7862
    Digiratus
    Roaming the PNW
    The RedHead
    Ask then for a print out of the results so you can share them. :D They wont do it unless you ask for the report.
  3. Apr 6, 2012 at 8:12 PM
    #7863
    MTgirl
    Weesa
    Bob's secret mod lair
    :wave: Hi Mike! How ya been?
  4. Apr 6, 2012 at 8:16 PM
    #7864
    Digiratus
    Roaming the PNW
    The RedHead
    :eek: Sometimes a BFH just isn't enough. You should see my one stcok upper control arm. It has definately been abused by a hammer and it still would not come off the ball joint. A 3 armed puller popped it and the other side off easly. It did sound like a gunshot when it popped though
  5. Apr 6, 2012 at 8:18 PM
    #7865
    Digiratus
    Roaming the PNW
    The RedHead
    Hi Lisa. I'm doing fine. And you? How are things in Bozo Town? :p
  6. Apr 6, 2012 at 8:33 PM
    #7866
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This is BDawg checking in :spy:
  7. Apr 6, 2012 at 8:45 PM
    #7867
    Digiratus
    Roaming the PNW
    The RedHead
    Hey Buddy. Kinda quiet in here tonite. Only you, me and Lisa have showed up so far. :popcorn:
  8. Apr 6, 2012 at 8:46 PM
    #7868
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  9. Apr 6, 2012 at 8:48 PM
    #7869
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it has slowed down here the last few days. Think School is just catching up with most of us haha
  10. Apr 6, 2012 at 8:55 PM
    #7870
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
  11. Apr 6, 2012 at 8:58 PM
    #7871
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bout time
  12. Apr 6, 2012 at 8:59 PM
    #7872
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    sorry i left you hanging monte
  13. Apr 6, 2012 at 9:00 PM
    #7873
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    might go fox... 650 spring rate may not be enough once the skids go on... I hate you guys :p
  14. Apr 6, 2012 at 9:01 PM
    #7874
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    how much does your winch and skids really weigh?
  15. Apr 6, 2012 at 9:03 PM
    #7875
    Blackdawg
    Monte
    Wyoming/St. Louis
    Better be..lol
    You getting coil overs?
    You have the 4.0 right?
    If you have a plate bumper, winch, and skids..id get a 700lb coil man..
  16. Apr 6, 2012 at 9:04 PM
    #7876
    KalamaKid
    Oregon
    100 for bumper
    110 for winch
    90 for skids
    added moment from sliders
    dual battery will add maybe 60lbs also
    I have a 600lb coil right meow
  17. Apr 6, 2012 at 9:05 PM
    #7877
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea..get a 700lb coil bro lol
  18. Apr 6, 2012 at 9:06 PM
    #7878
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    that's quite a bit of weight.... i'd go 700-725...
  19. Apr 6, 2012 at 9:07 PM
    #7879
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    are we talking progressive springs or static?
  20. Apr 6, 2012 at 9:07 PM
    #7880
    KalamaKid
    Oregon
    you're running the same weight man!
