Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 9, 2012 at 11:01 PM
    #8261
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    my fire wall is stuffed with wires i may have to start drilling new holes if i add an more wires.
  2. Apr 9, 2012 at 11:03 PM
    #8262
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    me to man tho my 0 gauge cable for stereo is taking up a lot of room...:anonymous:
  3. Apr 9, 2012 at 11:46 PM
    #8263
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    holy shit thats a lot of wire! 140 feet! that just seems like an excessive amount. just curious adam, if you are doing a build of this magnitude why are you dealing with crap lights? been there done that, and its annoying when you want to replace em for actually good lights. why not just buy good lights to begin with?
    he is high if he thinks that is 100 feet...
  4. Apr 9, 2012 at 11:48 PM
    #8264
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty sure the crap lights are for side and rear firing. all the LFs are front firing.
    I'm just gonna get 4 cheap square lights for side and rear firing.
  5. Apr 9, 2012 at 11:53 PM
    #8265
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    There is no need to have stellar lights one the side and back of the rack. LF would be over kill I've thought about getting RI duallys with diffuser lenses but unless i get a sponsor ship from them it's not going to happen that's another thousand dollars in lighting that i could use for lockers instead.
  6. Apr 10, 2012 at 12:28 AM
    #8266
    Blackdawg
    Monte
    Wyoming/St. Louis
    Adam..were did you get that battery separator again??
  7. Apr 10, 2012 at 12:30 AM
    #8267
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    from the looks of it it would be a simple build.
  8. Apr 10, 2012 at 12:31 AM
    #8268
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  9. Apr 10, 2012 at 12:31 AM
    #8269
    Blackdawg
    Monte
    Wyoming/St. Louis
    It is..just need the solenoid
  10. Apr 10, 2012 at 12:33 AM
    #8270
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. Apr 10, 2012 at 12:35 AM
    #8271
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I used about 6ft of 4g wire to make it all work
  12. Apr 10, 2012 at 12:37 AM
    #8272
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well ill end up mounting my aux battery on the pass side i think. More room over there and both my current light relays are right there lol but maybe not..idk yet. That won't happen till June i bet.
  13. Apr 10, 2012 at 12:40 AM
    #8273
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It's super easy but I will warn you the terminals on the isolator are pretty big and the standard 4g crimp terminals won't fit over them I had to drill the rings to make them bigger to fit on the isolator.
  14. Apr 10, 2012 at 12:41 AM
    #8274
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    omg, i actually own something of use you want to use...didnt think that would ever happen lol. i returned the 2ft auz cable to go from the cb to the meter though lol. so we need another one of those.
  15. Apr 10, 2012 at 12:44 AM
    #8275
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    that's fine I can pick on up I still need an antenna and coax
  16. Apr 10, 2012 at 7:22 AM
    #8276
    BradyT88
    BradyT88 Well-Known Member
  17. Apr 10, 2012 at 7:46 AM
    #8277
    BradyT88
    What's up Ben?
  18. Apr 10, 2012 at 8:01 AM
    #8278
    BradyT88
    When was this and where are those pictures?!! :worthless:
    That is pretty strange. haha.
  19. Apr 10, 2012 at 8:05 AM
    #8279
    BradyT88
    The images were sent down to the MCC for further analysis by flight controllers, who were concerned about the possibility that the object may have come off Atlantis, and as such wished to identify the object. The most likely scenario was that the object was benign, such as ice or a piece of shimstock (observed earlier in the flight protruding from the heat shield) that may have shaken loose.[39] However, the possibility remained that the object may be of critical importance, such as a tile from the Orbiter's thermal protection system.
    That came from wikipedia.
    That's a strange looking picture, but they said they pics were of too low of resolution to really identify the object. I think a piece of ice sounds reasonable though.
  20. Apr 10, 2012 at 8:16 AM
    #8280
    BradyT88
    If the universe is as massive as we currently think it is then I think there has to be at least one other planet out there with life on it, but unless they are millions of years more advanced than us or we prove Eistein wrong and become capable of traveling at speeds thousands of times faster than the speed of light, we may not ever find them.
    At least not until we start inhabiting other planets and our territories bump up against each other, and without faster than speed of light travel that could take eons...
