Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 11, 2012 at 10:44 PM
    #8481
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I sent you a picture home slice!!!!
  2. Apr 11, 2012 at 10:47 PM
    #8482
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    oh, didnt get a lil update on my phone. soz:eek: wait, when does the full metal bed thing get put together? looks pretty legit so far, can i put a chair up there and ride in it like im the commander of a tank?
  3. Apr 11, 2012 at 10:48 PM
    #8483
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Mark I don't think you need to remove the fan to replace that belt there should be some sort of tensioner to keep the belt tight. one of those two pulleys has to be adjustable. and and the good news is that because it got quieter with the water the problem is a belt and not a bearing.
  4. Apr 11, 2012 at 10:48 PM
    #8484
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    once it's finished I'm sure you could go for a ride up there.
  5. Apr 11, 2012 at 10:52 PM
    #8485
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    what i believe is the tensioner is the pully on the left side of the belt by the oil dip stick. but of you can see the black piece of metal the bolt through is bending, so im not sure how much tighter i can get it. and the belt goes up top to the power steering pump pully and down around the fan shaft. im not sure how i could get it off and get a new one back on with the fan in the way.
    sweeeeeeet:turtleride:
  6. Apr 11, 2012 at 11:00 PM
    #8486
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    That top bolt needs to be loosened
    if that is a tensioner you can stick a 3/8s"s ratchet in to the arm and loosen the pulley i believe.
    if that does't work try to loosen that bolt you're starting to bend the bracket on.. you can bend it back no big deal
  7. Apr 11, 2012 at 11:02 PM
    #8487
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Hey guys, this is just a BS thread. Just stopping by.
    I'm single after a year with her. Oh well. Nothing I did wrong at all, and she told me that. She has just changed as a person and didn't love me like I loved her.
    Got any fun suggestions to get over someone?
  8. Apr 11, 2012 at 11:02 PM
    #8488
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  9. Apr 11, 2012 at 11:03 PM
    #8489
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    blow then hooker, then blow from the hooker
  10. Apr 11, 2012 at 11:05 PM
    #8490
    YellowDog01
    04 4x4
    Ha man I'm just not a partier. Just a pretty quiet guy
  11. Apr 11, 2012 at 11:08 PM
    #8491
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I wasn't sure if you were serious or not
  12. Apr 11, 2012 at 11:09 PM
    #8492
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    what up everyone.
  13. Apr 11, 2012 at 11:10 PM
    #8493
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    slow night here monte
  14. Apr 11, 2012 at 11:10 PM
    #8494
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    what do you mean with the bold part?
    ill loosen up the bolt tomorrow when i have some more light. you think that would just make it squeak more?
  15. Apr 11, 2012 at 11:10 PM
    #8495
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Honestly man, even if your not a partier just go out with some of your buddies. you dont need to drink or get hammered by any means but going out and having a good time with your buds is the best way I ever dealt with that stuff.
    hi monte
  16. Apr 11, 2012 at 11:12 PM
    #8496
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  17. Apr 11, 2012 at 11:13 PM
    #8497
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    broseph you need a new belt.
  18. Apr 11, 2012 at 11:15 PM
    #8498
    Blackdawg
    Monte
    Wyoming/St. Louis
    what we talking bout? Partying?
    I don't do it either.
  19. Apr 11, 2012 at 11:15 PM
    #8499
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    tough one man. sorry to hear. honestly? its probably just going to take time. you could always go out and try to pick up that other girl you have had your eyes on (if one such exists). that might get your mind off it.
  20. Apr 11, 2012 at 11:15 PM
    #8500
    YellowDog01
    04 4x4
    577538_10151530334355228_636015227_23698_1b310f5f8f09e1e8ad035b70a2f436991104b663.jpg
    One step ahead of you
