Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 12, 2012 at 4:16 PM
    #8581
    BradyT88
    BradyT88 Well-Known Member
    Um... I hate to say it, but maybe it's a good thing you're not dating her anymore... Sounds like there was something going on behind your back... Sorry man...
  2. Apr 12, 2012 at 4:21 PM
    #8582
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    I agree. Pretty shitty situation.
  3. Apr 12, 2012 at 4:31 PM
    #8583
    YellowDog01
    04 4x4
  4. Apr 12, 2012 at 4:34 PM
    #8584
    BradyT88
    Who the fuck writes these laws?!!:rolleyes: haha. IMHO if you can train a beaver to catch fish for you, you sir, deserve those fucking fish.
  5. Apr 12, 2012 at 4:51 PM
    #8585
    BradyT88
    Because I have your posts to read on TW:D And at least I'm not in Jerome of all places;)
  6. Apr 12, 2012 at 5:07 PM
    #8586
    BradyT88
    Fixed:D
    (fuck... I couldn't find a good pic for that...:pout:)
  7. Apr 12, 2012 at 5:18 PM
    #8587
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    the only way to fix your caster is with UCAs
    other than that the number look ok.
    the truck will pre pretty darty until you get UCAs.
  8. Apr 12, 2012 at 5:22 PM
    #8588
    BradyT88
    :rofl: thats good. I was expecting a different come back.
  9. Apr 12, 2012 at 7:13 PM
    #8589
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  10. Apr 12, 2012 at 7:14 PM
    #8590
    BradyT88
  11. Apr 12, 2012 at 7:33 PM
    #8591
    BradyT88
    I guess none of the people were severely injured:), which blows my mind when you look at how damaged severval of those vehicles are:eek:
  12. Apr 12, 2012 at 7:59 PM
    #8592
    BradyT88
  13. Apr 12, 2012 at 9:00 PM
    #8593
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    That's pretty cool thanks Chris.
    I got my antenna and coax adaptor in today still waiting for my coax to show up
  14. Apr 12, 2012 at 9:14 PM
    #8594
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There is good news here. They were able to get the toe and camber pretty good. This will assure no abnormal tire wear, which is and should be their priority. Is the steering wheel straight? Does it pull to one side or the other when you let go of the wheel?
    Most importantly, you seem happy with the way it drives, at least so far. I can appreciate that. I drove mine without aftermarket UCAs with a similar amount of lift for almost 2 years. And my alignment numbers were very similar to yours.
    The dartinesss that adam mentioned and the ease with which side winds moved the truck around at higher speeds and also the vulnerability to highways with truckk ruts eventually got to me so I made the change. You'll have to decide for yourself whether your caster settings are tolerable.
  15. Apr 12, 2012 at 9:16 PM
    #8595
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    My caster setting drove me nuts the UCAs were a non question.
  16. Apr 12, 2012 at 9:18 PM
    #8596
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It should handle the same as it did before maybe a bit stiffer
  17. Apr 12, 2012 at 9:30 PM
    #8597
    Digiratus
    Roaming the PNW
    The RedHead
    I think you had some ball joint bind issues though too didn;t you? Your front suspensions just wasnt free to move correctly til you added the camburgs.
    I have to agree. Ben, where you will notice it most will be a 70 mph on the interstate.
  18. Apr 12, 2012 at 9:34 PM
    #8598
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    yea my truck was the same way after the lift without UCAs.
    I WANT MY FUCKING RACK.
  19. Apr 12, 2012 at 11:25 PM
    #8599
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  20. Apr 12, 2012 at 11:30 PM
    #8600
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I think I'm the only reg cab going to moab
