Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 13, 2012 at 1:20 PM
    #8621
    MTgirl
    Weesa
    Bob's secret mod lair
    does it smell fishy? gear oil has a fishy odor to it
  2. Apr 13, 2012 at 1:26 PM
    #8622
    BradyT88
    BradyT88 Well-Known Member
    Haha. well the round case that protects the axles;) after googling it, I guess the technical term would be the rear axle housing:D
  3. Apr 13, 2012 at 1:27 PM
    #8623
    MTgirl
    Weesa
    if it was brake fluid your resi would be low, have you checked it?
  4. Apr 13, 2012 at 1:30 PM
    #8624
    BradyT88
    Didn't notice a smell... although my gear oil in the back is only about 5 months old and has about 500 miles on it. Although I have 6 qts of new gear oil sitting here next to me and that stuff has a strong smell. haha
    So just how hard is it to change the seal and/or bearing?
  5. Apr 13, 2012 at 1:36 PM
    #8625
    BradyT88
    Brake fluid level is fine, even after pumping the brakes some. It's got to be that seal or bearing...
    and what exactly would cause that to go out? I haven't even drove it on the freeway for at least a week so it can't have over heated at 35mph...
  6. Apr 13, 2012 at 1:41 PM
    #8626
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    That my friends is the tell tale sign of....... AN AXLE SEAL. they are kind of a pain to replace. you need to remove the tire, then the break drum and axle as once piece. you'll have to bleed the brakes once you put it all back together, just be careful not to damage the bearing surface coming out or going back in.
  7. Apr 13, 2012 at 1:42 PM
    #8627
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    they just go bad it's a wear part it's got a shaft spinning on it anytime the truck moves.
  8. Apr 13, 2012 at 1:44 PM
    #8628
    BradyT88
    Would a bad bearing cause it to leak? I was noticing not too long ago that i think my taco is making a sound like the brakes are rubbing. I was going to wait until I had more time to jack it up and play with it before I talked to you guys about it though...
  9. Apr 13, 2012 at 1:44 PM
    #8629
    BradyT88
    With less than 15,000 miles on it? Although age is probably a factor in this too...
    Don't die on us yet old man;);):cool:
  10. Apr 13, 2012 at 1:45 PM
    #8630
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    it's possible but you certainly have a seal problem and it's the cheaper of the two to fix labor would be about .25 hours more to replace the bearing with the seal. Expect about 20 in labor and 50-75 in parts
  11. Apr 13, 2012 at 1:51 PM
    #8631
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  12. Apr 13, 2012 at 1:53 PM
    #8632
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Gear oil is some nasty shit and loaded with detergents it smells like sulfur and dirty diapers brake fluid will remove any paint it touches.
  13. Apr 13, 2012 at 2:56 PM
    #8633
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    what did i miss yesterday?
  14. Apr 13, 2012 at 3:01 PM
    #8634
    BradyT88
    Well it was inside the brake drums, and its still scentless as far as I can tell. The bearing doesn't make any noise when I spin it either. On a side note...:frusty: lessoned learned I hope... Do not press the brake pedal with the brake drum covers off... Did I just fuck this piston? I can't get that red thing to go back in no matter what i do...
    :frusty:
  15. Apr 13, 2012 at 3:05 PM
    #8635
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think you might just have to start the truck again..but not totally sure on that..
  16. Apr 13, 2012 at 3:15 PM
    #8636
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Don't do that. Just open the bleeder on that cylinder and push it back in. Some fluid will squirt out and you should bleed the brakes after that, but I bet your mysterious oil is brake fluid and you know what that means.
  17. Apr 13, 2012 at 3:46 PM
    #8637
    BradyT88
    Fixed!! I took the whole piston off and tore it apart. The seal on the red thing got caught and wouldn't let it go back in.
    and that mean my brake piston is bad? I'm a newb...
  18. Apr 13, 2012 at 4:28 PM
    #8638
    BradyT88
    Alright... I'm having a great Friday the 13th... How retarded can I be in one day... So I got it all put back together, bled the brake line on the drivers side since I tore that piston apart and went to check the brake fluid to add some... Remember when I said I checked the brake fluid earlier and it was fine? I checking the fucking power steering fluid!!!! I think my brain is broken... my jaw literally dropped when I realized that... as for the initial leak on the passenger side, I'm thinking it is brake fluid, cuz I took the fill bolt off of the rear diff and it dripped right away and I could smell it instantly. So bad piston on that side?
  19. Apr 13, 2012 at 5:02 PM
    #8639
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I doubt your piston is bad maybe the seal. one of the local parts places should have a rebuild kit for 20 bucks or so.
  20. Apr 13, 2012 at 5:19 PM
    #8640
    BradyT88
    Nice thanks. I'll have to look into that. Too bad i don't have time this weekend to play with it...
    Hell I just found the entire piston online for $25 and free shipping.
