Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 25, 2011 at 11:00 PM
    #941
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not necessarily the starter itself, the solenoid contains high amp copper contacts that can develop burned areas that add resistance.
    Seems like there are several threads regarding solenoid issues on TW.
  2. Dec 25, 2011 at 11:21 PM
    #942
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Does that sound like a solenoid issue than? Can I clean it and fix it?
  3. Dec 26, 2011 at 2:16 AM
    #943
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Sounds like the contacts are done, pretty soon you will be hitting it with a hammer to get it started. Just take it to toyota and they will rebuild it for $100
  4. Dec 26, 2011 at 8:34 AM
    #944
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh sweet! Thats a pretty good price. Now 20 or 30 ft...what a difficult, decision.
    Well dam, I didn't want to be doing 100 dollar repairs 2 weeks after getting it. I just can't get over how it didn't do this before the lights, now all of a sudden its doing it all the time.
  5. Dec 26, 2011 at 10:29 AM
    #945
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    new update for everyone tired of hearing me bitch about my starter...i turned it on this morning (took 3 clicks than turned over) and drove to get gas and go to the auto part store. at the auto part store i shut it off and went to turn it back on again and it fired up instantly each time. so whoever said it was a cold start issue...i think you are right. so now im going to remove it and take it to oriley and get it tested.
  6. Dec 26, 2011 at 10:41 AM
    #946
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Sickk! What are your gus plans
  7. Dec 26, 2011 at 12:51 PM
    #947
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well I took the starter off, massive, massive pain in the ass, and had it tested and the starter is fine...so its gotta be something with the wiring somewhere. This is incredibly fucking frustrating and I'm getting so pissed at this dam thing
  8. Dec 26, 2011 at 6:02 PM
    #948
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Maybe it is the cold start issue? There if the starter is good the battery is good..... Have you check the plug and the plug wires?
  9. Dec 26, 2011 at 6:09 PM
    #949
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    And whoever is looking at recovery straps get the 30 footer you can always fold it in half and make it 15ft. I picked up a new 30klbs 30' footer because I broke my last one
  10. Dec 26, 2011 at 8:15 PM
    #950
    Manwithoutaplan
    ID
    anybody going to be in moscow tommorrow or wednesday want to meet up??
  11. Dec 26, 2011 at 8:35 PM
    #951
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    What is the "cold start issue". Isn't that a problem with the solenoid?
  12. Dec 26, 2011 at 8:42 PM
    #952
    Manwithoutaplan
    ID
  13. Dec 26, 2011 at 10:46 PM
    #953
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I have loops on both ends but I bought a shackle for my receiver almost every body has a ball hitch I can hook the other end to.
  14. Dec 26, 2011 at 10:54 PM
    #954
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    That is exactly what I have
  15. Dec 26, 2011 at 10:56 PM
    #955
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    04 I maybe out your way sometime next week
  16. Dec 26, 2011 at 11:01 PM
    #956
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm headed to my buddys shop in Longview to start fabbing up some skid plates
  17. Dec 26, 2011 at 11:03 PM
    #957
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I hope so I need to protect my under sides from rocks
  18. Dec 26, 2011 at 11:04 PM
    #958
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    ... And Ben he needs protection from rocks too
  19. Dec 26, 2011 at 11:08 PM
    #959
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Haven't decided yet I need to take a good look at what under there. I want to add some cross braces and attach the plate to those so if I bang on up I just have to replace one piece of plate instead of a whole skid plate that is 2-300 dollars
  20. Dec 26, 2011 at 11:14 PM
    #960
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'll have to check them out too I need to build a hi lift mount too mine should be here soon
