Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 25, 2012 at 10:24 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    fine
    i'll be back in 10 mins
  2. Apr 25, 2012 at 10:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There are two basic types. One is very aggressive, the other is less so. If you find out it is a GB type and want some insights, let me know. I have experience with GBs and what your friend is up against. :(
  3. Apr 25, 2012 at 10:39 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ADAM YOU ASSHAT I HAD THE PIC AND EVERYTHING:( i was gonna win, then set the next challenge in your name
  4. Apr 25, 2012 at 10:41 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    haha I left my house went down the road pulled up on the hill took 9 pictures and went back home uploaded to my computer then posted...
    did mommy get mad at you driving on the steps? :D
  5. Apr 25, 2012 at 10:44 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    no, she was mad when i shook the house after leaving a bumper shaped dent in the trim on the corner of the house after using too much skinny pedal...dam challenge thread is gonna cost me a pretty penny
    did your uncle make you drive down the road because he didnt want your bright ass bro lights shining up the place?:D
  6. Apr 25, 2012 at 10:47 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    no they are out of town
    I need a vote you have 5 mins for the next challenge.
    Girl in a bikini washing the truck with the date written on a plastic cup.
    or
    backwards though a drive through with a picture of you getting your order.
  7. Apr 25, 2012 at 10:49 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    no not really lol. you think i'm that bad...oh god nobody has any faith in me
    had to use 4wd though, didnt want to lift a tire off the ground and be stuck spinning a wheel with my open diff truck:anonymous:
    also jk:D
    drive through, much more fun!
  8. Apr 25, 2012 at 10:50 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  9. Apr 25, 2012 at 10:54 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    not hating here....but REALLY what is the need for full plate armor on an otherwise stock 5 lug base...even if lifted....thats a bit much
  10. Apr 25, 2012 at 10:56 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    every tried to park in LA?
  11. Apr 25, 2012 at 10:58 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    good job!
    err'y day!
  12. Apr 25, 2012 at 11:00 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    gotta go hard n LA brah bitches can't park of shit
  13. Apr 25, 2012 at 11:02 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i don't know what's worse as far as bro's go
    phx to so cal.
  14. Apr 25, 2012 at 11:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  15. Apr 25, 2012 at 11:07 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    im stealing that and making a clothing line you can have 5% of the profits
  16. Apr 25, 2012 at 11:11 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    BORED!!!!!
  17. Apr 25, 2012 at 11:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i want to get a sticker like the caterpillar ones people put across their front windshield that says that lol
    thats funny
  18. Apr 25, 2012 at 11:13 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    PM incoming
  19. Apr 25, 2012 at 11:18 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    You guys think an actuator is worth it for a light rack?
    Im starting to think it might not for the money ppl want for them.
  20. Apr 25, 2012 at 11:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    What did i miss?
