Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 26, 2012 at 8:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    not when i was there!...
    actually..it was mostly Mike and I...
    now put a CB in your hand and jesus..lol
  2. Apr 26, 2012 at 8:47 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    let the apple juice flow
  3. Apr 26, 2012 at 8:48 PM
    BradyT88
    BradyT88 Well-Known Member
    I've got two 12's on an mono amp and then four 6x9's on a 4 channel amp. The 12's are set up on a low pass filter and 2 of the 6x9's are running on a high pass filter with the other 2 set for the mid range; and with no speakers running off the head unit I can crank it up all the way and it still sounds great:D
  4. Apr 26, 2012 at 8:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think you can pretty much count on that happening.
  5. Apr 26, 2012 at 8:51 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Yea having a HPF and LPF is nice my tweeters only do 800hz+ and the 6.5" do 125hz-800 and the subs do 30hz-125.
  6. Apr 26, 2012 at 8:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm betting it will be different this time. :cool:
  7. Apr 26, 2012 at 8:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not as good as a headunit upgrade and amping them.
    i have two 1000w RMS 10'' subs on LP of about 180hz with main boost at 100hz. My 6x9s are run off the rear channel of my other amp on full range on the amp but i have a HPF set at 125hz on the HU. Then the front channel drives all 4 of my other speakers in series with a HPF on the amp at about 300hz.
    i have never turned mine up all the way..to scared too. around 40 is so god damn loud its ridiculous. was parked out front about 250ft from my house and my parents called me to turn it down as it was rattling the kitchen dishes...on the other side of the house :anonymous: I never do that now tho. My ears are too precious.
  8. Apr 26, 2012 at 8:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You had it in reverse for some reason. :facepalm::crazy:
  9. Apr 26, 2012 at 8:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    id have the tweeters on like 2k up.
  10. Apr 26, 2012 at 8:59 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    2k isn't an option on my HU i can do 800, 1.5k 5k or 12k
  11. Apr 26, 2012 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..odd..well then do 1.5k :p haha
  12. Apr 26, 2012 at 9:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    just curious, how much extra oh shit money do you guys plan on having?
  13. Apr 26, 2012 at 9:03 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Pm incoming
  14. Apr 26, 2012 at 9:12 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ALSO, whats the lowest psi you can run while driving on the road at about 40mph
  15. Apr 26, 2012 at 9:15 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    probably less than a mile from road to wheeling spot to gas station. so i can run like 18 psi on the road without blowing beads or killing the tire if its just for a mile?
  16. Apr 26, 2012 at 9:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    1k
    you have an amp for your speakers??
    i have done 15psi. My wheelers rims tho have a much bigger lip tho then stock rims. i could do 10 and be fine.
    i have done 15 tho on my old stock rims and gone 50ish and was fine.
    id be curious tho if jeep rims lips are bigger then the stock toyota rims..
  17. Apr 26, 2012 at 9:30 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    good to know! thanks!
  18. Apr 26, 2012 at 9:34 PM
    BradyT88
    Haha. Epic!:cool:
  19. Apr 26, 2012 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    stupid cats lol
  20. Apr 26, 2012 at 9:37 PM
    BradyT88
    I believe that I am headed for your place during the zombie apocalypse;) Although the father in law's is closer. I just need to be sure to bring lots of ammo with. We ran him a bit low last time I was there:D
