Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 2, 2012 at 10:16 PM
    #1061
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    its probably a canadian bug you brought back. might require a quarantine.
  2. Jan 2, 2012 at 10:32 PM
    #1062
    Digiratus
    Roaming the PNW
    The RedHead
    Has the CDC contacted you yet? :eek:
  3. Jan 2, 2012 at 10:47 PM
    #1063
    Digiratus
    Roaming the PNW
    The RedHead
    Doin well. Been trying to figure out what all I want to do for Moab.
    My friend Mark (TW= The Raisin) is going to come with but not with his
    tacoma. In fact, we will likely be coming in his '07 Tundra, towing my truck on a trailer. :eek:
  4. Jan 2, 2012 at 10:52 PM
    #1064
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    woa holy cow that looks like quite a bit of droop. here was my springs with 500lbs of dirtbike in the back
    no i def want a lift, but i bet the AALs will help with hauling more then just some adjustable shocks.
  5. Jan 2, 2012 at 11:01 PM
    #1065
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Yeah you could go with the one coils but im not sure if it can match.with 5100s. Also if you want a bumper eventually you will have to upgrade your ome coils to a stiffer one. An aal will suit you just fine and will help with hauling. You probly will be able to fit 33's but trimming and a good bs wheel will be needed
  6. Jan 2, 2012 at 11:12 PM
    #1066
    Digiratus
    Roaming the PNW
    The RedHead
    No, he doesn't wheel the Tundra. Around here it just doesn't make sense, those things are big! No, he's alays wanted to go to Moab but his Tacoma isn't ready so he's coming to be our spotter. :D
    Do you have access too a floor jack?
    Assuming its a front wheel bearing, lift the wheel off the ground to first see if you hear a crunching noise when you spin the wheel by hand. Also, grab the wheel at the 12 o'clock and 6 o''clock positions and see if you can get it to wiggle.
    If it wiggles at all or if you hear it crunching when it spins it is the sign of a bad wheel bearing. These techniques only apply to the front bearings.
  7. Jan 2, 2012 at 11:27 PM
    #1067
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    trimming where specifically. and a bs wheel? the hell does that stand for lol. would it just be better to get 32 and not need to deal with all of the little stuff needed for 33s?
  8. Jan 3, 2012 at 12:48 AM
    #1068
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You will have to trim the front side inner wheel well. specifically the corner of the bumper area.
    Your wheels will have to stick out more so you dont rub on the frame so you would need around 3.5-4" bs
  9. Jan 3, 2012 at 12:49 AM
    #1069
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Ben I'll check out your wheel bearing when we meet up there is an easy way to check I'll show you.
  10. Jan 3, 2012 at 9:03 PM
    #1070
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    monday was a federal holiday no mail hommie
  11. Jan 3, 2012 at 9:09 PM
    #1071
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    where did you order it from?
  12. Jan 3, 2012 at 9:25 PM
    #1072
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    should have told me i have a prime acct and free like 4 dollar 2 day shipping
  13. Jan 3, 2012 at 9:31 PM
    #1073
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I also say CopyTaco today when I was driving to meet up with another member
  14. Jan 3, 2012 at 11:55 PM
    #1074
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i think he lives on the hill across from mine i've seen his truck a couple times now
  15. Jan 4, 2012 at 12:14 AM
    #1075
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I guess vendors don't want money. sucks to be them. now i need to find a new one for a bumper.
  16. Jan 4, 2012 at 4:08 PM
    #1076
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  17. Jan 4, 2012 at 4:15 PM
    #1077
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    pm'd
  18. Jan 4, 2012 at 4:29 PM
    #1078
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    replied to all PM's
  19. Jan 4, 2012 at 5:31 PM
    #1079
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Another glorious day of skeet shooting. also did some off roading...through some mud. I had some extra time so i just headed down this trail that looked like it went out the right way toward the road. Well after 20 minutes of slow roudh driving down this trail it just ends along this barb wire fence behind someone's country house. Regrettably i turned around to head all the way back when my friend notices a semi clear field next to this guest house on the property that leads to a gravel road then out to the main road. So i go through their back yard/field thing into their driveway in front of the house and haul ass down the gravel drive to get to the main road. it was a great day lol.
  20. Jan 4, 2012 at 9:55 PM
    #1080
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    so we going wheeling friday or saturday or friday into saturday?
