Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 29, 2012 at 11:28 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i might be trying to find a way to get my sub in the cubby hole for the drive down. connor ill pick you up from slc and you can sit on the sub the whole ride and get a "massage"
  2. Apr 29, 2012 at 11:31 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    hmmm I'll be at your place around dinner time saturday the 12th we might be able to install it that night if you aren't working
  3. Apr 29, 2012 at 11:31 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Do you have to plug her into a tree? Oh that's right, 2nd gens have a power inverter in the bed. Toyota engineers were smart in making their trucks plug in blow up doll compatible! Now if only they had put that same thought into that leaf spring tsb...
  4. Apr 29, 2012 at 11:32 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It's ok I have VVT-i
    and ben has V-TEC with his honda exhaust
  5. Apr 29, 2012 at 11:34 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    eh, if its going in it should be in before that. I have everything I need. I just pulled it all out of my last truck so every wire is cut to the exact right lengths and everything. I just have to see how well the 10 will fit and how much metal trimming I will need to do. If I need to trim too much metal Ill just go trade the 10 for an 8. Ill probably just go trade the 10 in for an 8 so i have a good clean fit.
    sounds good though. We will find out specifics as the date gets closer.
  6. Apr 29, 2012 at 11:35 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    also here you guys go, i made everyone sandwiches
  7. Apr 29, 2012 at 11:35 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'll be honest it was a pain in the ass squeezing a 10 into my baby truck
  8. Apr 29, 2012 at 11:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    how are you wanting to mount it?
  9. Apr 29, 2012 at 11:40 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    any of you audiophiles will want to not read this...but im cutting some mdf...and putting it over the hole in the large cubby in the back seat...and putting a sub through circle in said mdf...done.
  10. Apr 29, 2012 at 11:42 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you forgot your bag :anonymous:
  11. Apr 29, 2012 at 11:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :confused:oh ok. here pass that guy here, gotta put a bag over that shit :anonymous:
  12. Apr 29, 2012 at 11:47 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    :anonymous:
    Too much derp in other threads, it sometimes gets thrown cross forum :eek:
    I really do want to go, but besides going straight awol and abandoning the shifts I said I'd cover for guys. I can't swing it :(
  13. Apr 29, 2012 at 11:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not a bad idea. Its been done. I think you will need an 8 tho.
    also get some foam sealant to fill the two large holes in the bottom corners. Will make it sound much much better
  14. Apr 29, 2012 at 11:54 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Speaking of filling holes i need to re glass my box it's got a leak somewhere
    I also need to re seal the back of the cab
  15. Apr 29, 2012 at 11:55 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    wha?
  16. Apr 29, 2012 at 11:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    thats what my friend said, just line the bottom with this foam crap so it slows down the air and i get better quality. and i think you are right. I dont want to hack up the bench floor to notch it for a 10.
  17. Apr 29, 2012 at 11:56 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    fuck it just get clothes there. hop in a rental and go to the outlets just south of vegas
  18. Apr 29, 2012 at 11:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Jason has two 8s, one in each hole.
    but you def want to seal it up good. then id put some pillow cotton in there as well. would sound just fine
  19. Apr 29, 2012 at 11:59 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    :sorry: i failed you
  20. Apr 30, 2012 at 12:00 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i can only think of one thing that is 8" and in each of jason's 2 holes
