Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 30, 2012 at 5:56 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    his stick out pretty far too
  2. Apr 30, 2012 at 5:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    im looking forward to having short people get in :devil:
    im going to ask around for an angle grinder and if i cant find one ill just go buy one. not a chance in hell im going to do it by hand
    test fit to mark off where to grind...so stoked
  3. Apr 30, 2012 at 6:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea mine start at 1.5" out and flare to about 3-4 before a 6-8" kick out. I do like having then as steps. Will be great foe the roof rack
  4. Apr 30, 2012 at 6:03 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ALSO! this white...90s land cruiser (solid axles front and rear, diff locks, sliders, 34x12.5" bfgs, plate bumper, tons of off road stickers) that I see at school every now and then parked right next to me in a lot that had at least 10 other open spaces. Might have just been a coincidence, but i doubt it. So I put my screen name for planet 4x4 and asked if he wanted to go wheeling some time and left it under his wiper blade. Now, I wait.
  5. Apr 30, 2012 at 6:29 PM
    BradyT88
    BradyT88 Well-Known Member
    Well the CB is like half way installed. I have power ran, I just need to attach it to the fuse box or battery under the hood. Now I am waiting on the antenna and coax cable to finish it out.
  6. Apr 30, 2012 at 6:31 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Just put one of these on your ACC fuse behind the coin tray
  7. Apr 30, 2012 at 6:54 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I ran my power directly to the battery for the CB. Got to test it out this weekend it still needs some tuning but but I could buck up Ben from 7 miles away.
  8. Apr 30, 2012 at 6:56 PM
    BradyT88
    What?! There's a fuse box behind the coin tray?:confused: i already ran a wire up to the battery. Haha:rolleyes:
  9. Apr 30, 2012 at 7:12 PM
    KalamaKid
    Oregon
    Then just tap into the IGN fuse next to it? The buss behind the coin tray fuse box always has power
  10. Apr 30, 2012 at 7:17 PM
    BradyT88
    I'll be damned there is a fuse box behind there. You'd think that would be labeled or something. haha
    There's the little hole I cut in the bottle of the console.
  11. Apr 30, 2012 at 7:24 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you console is twice as deep as mine
  12. Apr 30, 2012 at 7:34 PM
    KalamaKid
    Oregon
    Thats not the coin tray :eek:
  13. Apr 30, 2012 at 7:40 PM
    KalamaKid
    Oregon
    So how is a buss going to provide interference exactly? 14volts is 14 volts...
    Plus once the engine is started you are no longer receiving power from the battery as the battery is now the load and being charged from your alternator. Also if you really want to get technical electron's flow from the ground plane "frame" into the radio and back to the battery/alternator thus as long as your potential is stable it doesn't matter.
  14. Apr 30, 2012 at 7:49 PM
    BradyT88
    I know that isn't the coin tray. That is the hole i cut to run the coax cable up through. I am going to mount the cb in there. It stopped raining again so I ran out and finished the power cable and connected it to the battery and the cb works:D Now I get to play the waiting game for the coax and antenna. One flaw I just found though... I thought the speaker was in the mic not in the cb itself so I may not hear it with the console closed... Maybe I will run a audio cable from the cb to my stereo.
  15. Apr 30, 2012 at 8:04 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  16. Apr 30, 2012 at 9:08 PM
    BradyT88
  17. Apr 30, 2012 at 9:12 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  18. Apr 30, 2012 at 9:48 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    You know what else is hilarious??
    Mark and I have a secret mission. No homo
  19. Apr 30, 2012 at 9:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    SSSSSSSHHHHHHHHHHH
    :smack:
  20. Apr 30, 2012 at 9:54 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    U :jellydance: bro
